November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 03-18-2007, 10:25 PM
Default Another Victor manifold question
I have a Victor (not Victor Jr.) and Dominator 750 on a bored/stroked FE. When I stop, the car idles at about 1,100 RPM for a good 20 seconds, then slowy settles in at 850 RPM and stays there. Is this a characteristic of the manifold or the carburetor, or is something wrong?
Thanks,
Brian
Old 03-19-2007, 12:28 AM
Rick Parker's Avatar
I would be inclined to look at the internal linkage (if so equipped) on the carb. Sounds like the the throttle plates are sticking and closing a minor amount after engine idles for a few seconds. It could also be related to the centrifical advance mechanism in the distributor not returning to the base setting.
Rick
Old 03-19-2007, 09:05 PM
Two good ideas Rick. However, the symptoms did not appear when I used the Performer manifold with the same carb and distributor. Any ideas on manifold puddling or something else unique to the Victor?
Brian
Old 03-20-2007, 10:28 PM
RedCSX1's Avatar
Cobra Make, Engine: Shelby CSX 4766 (Vegas Built) with 482 Aluminum Pond motor
Check you power valve and see if the vac has changed.
Morgan LeBlanc
Fresno CA
