| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
05-07-2007, 06:44 AM
Ga.
Anyone running a JERICO 4-speed with a 427
Entertaining the idea of a JERICIO WC4, anyone run one?, If I decide to purchase I'll be selling two big-in big-outs.
Thanks,
Perry
Perry
Advertising
05-07-2007, 07:19 AM
Bigin/big out toploaders?
ratios/prices please?
DavidinDurango
mostly fords, with "some stuff"
05-07-2007, 08:55 AM
KY
Is this a track car or a street car? If it's a street car, a dog gear trans is gonna be more of a pain than fun.
05-07-2007, 11:24 AM
fl
Cobra Make, Engine: Superformance 695HP aluminum FE
Jerico
I am going to use a WC4 in my Superformance. Already fit, prepped and shifter fabricated. Car should be completed in a few weeks. I'll let you know what it's like.
JGC
05-09-2007, 07:26 AM
Ga.
Thanks JGC...
David, I'm entertaining the idea, no decision yet...
One of my top loaders has the new close ratio gear set from 'southern gear',
I really like it....
Perry
05-17-2007, 11:59 PM
BC
Although it isn`t a street car, I have been running a Jerico DR4 4speed in my 428CJ powered 78 Ford Fairmont drag car.After 6 race seasons in the Fairmont, and the last 2 seasons in my NHRA Stock Eliminator Mustang, I have yet to hurt the Jerico. Both cars get the clutch dumped at 6000+RPM, with slicks, and after a visual inspection the other day, it`s going back into the Fairmont, with all it`s old guts still intact. I doubt that the drag race Jerico would be much fun after a short while on the street, but a NASCAR version would likely be less annoying. But as for durability, I certainly have no complaints!
78 Fairmont 428CJ 4speed ET10.03@132.17mph
1985 Mustang 302 5speed 12.31@106.9mph
05-18-2007, 05:36 AM
OK
Cobra Make, Engine: SPF 148 with 427 SO
hey perry?
how do you like your big twin in line carbs? any trouble getting that all tuned?
05-18-2007, 05:48 AM
Ga.
At first it was adjust-drive-adjust-drive-adjust-drive......acceleration is unbelievable, Gotta feather the gas paddle to keep the tires from spinning.
I really need to change the cam to get full potential.
Perry
05-18-2007, 05:54 AM
OK
what intake are you running with those? I am seriously thinking about doing something differnt with my induction....I like the look. Where did you come up with the carbs?
Buzz
05-18-2007, 06:02 AM
Ga.
You'll need to find an old edelbrock 6X2 then be prepared to do a lot of measuring, machining and welding. The inlines come up on ebay every once in a while, I bought mine from an old racer in the Atlanta area.
As far as I know, I'm the only source for complete gasket sets, 875 and 1425.
Perry
05-18-2007, 08:28 AM
IL
Cobra Make, Engine: Everett-Morrison, 434 cid
I run a Jerico. The trans shifts best under full load...upshifting and downshifting... it is not suited to light-load gear changes. Part throttle cruising will also cause it to rattle alot. I have used it on the street but it is alot of work to get it shifted smoothly. I always figured I'd swap the trans out between track events... instead I just don't drive the car anymore.
I don't recommend it for a street driven car.
Scott
05-18-2007, 02:17 PM
ca
I've used Jericos in road-race cars - NASCAR Sportsmen. Don't recommend them for street cars. Putting them in first or reverse causes a gawd-awful noise. Some of the gears are straight cut and whine as a result.
They are unbelievably strong and quick-shifting, but are more similar to truck transmissions, meaning they need to be synchronized when downshifting.
I would figure out a way to drive a car with one already in it before going any further.
Good luck,
Brian
05-22-2007, 03:25 AM
Ga.
That's a good idea Brian, I'll check with jerico and ask who has one in the Atlanta area.
Thanks
Perry
