Old 05-17-2007, 04:06 AM
undy's Avatar
Originally Posted by RedCSX1
Strong recommendation on the intake. Blue Thunder is a high quality item.
...except when you buy one and the distributor hole is 1/4" off and Blue Thunder wants to kick you to the curb when asked to make it right.
Too many toys?? never!
Old 05-17-2007, 06:06 AM
Murphy's Avatar
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Thumbs up I agree with Chipbeck
I have the same setup in my Kirkham and it is a rocket. Keith Craft does it right. As an added plus he will talk to you when you call and follows up on what he says he will do. 1st class. Wrench87, I am running the Mass Flo system on my motor and it works fantastic. I asked KC to build the engine with the Mass-Flo intake and supply the package.
Caution, either have KC supply all the parts or buy the victor intake from Mass Flo as there is some minor machining required before you install. The Victor intake for fuel injection does not have a hole for the air charge sensor. Mass Flo knows this, so does Keith Craft. Edelbrock apperently does not.
Old 05-17-2007, 07:04 AM
RedCSX1's Avatar
Default I am sorry to hear that.
I would be upset as well. How did you find out the problem?
Morgan LeBlanc
Fresno CA
Old 05-17-2007, 05:17 PM
STEVE POTTS's Avatar
Cobra Make, Engine: Midstates, 427FE stroked to 482CI
Default dyno results on my 486FE...
570 HP and 596 lb-ft of torque...
Take a look...
http://www.clubcobra.com/photopost/s...00&ppuser=9667
Old 05-17-2007, 05:25 PM
Cobra Make, Engine: Kirkham, Pond Aluminum 482FE
Make that 3 of us...
Old 05-17-2007, 05:32 PM
undy's Avatar
....when I went to drop in the distributor and it wasn't even close. I ended up welding up the hole and having it fly cut on an end mill to the correct location, on my nickel.
Old 05-17-2007, 07:00 PM
Iceberg's Avatar
Cobra Make, Engine: SPF 2369; Keith Craft 427FE Alum w/614hp. & 1999 Lotus Esprit V8, 375hp
I went with Keith on my Alum Pond 482 and it is the best decision I have ever made. i love my engine.. Rob dyno'd a few months back and it was over 615hp. It is first engine that I ever had that scares me. It is a good kind of fear..
Kurt
Old 05-19-2007, 09:19 AM
82ACAUTOCRAFT's Avatar
Cobra Make, Engine: AC Frua, FE Side Oiler
I am curious, what is the maximum safe stroke for an original 427 SO block without clearancing the block?
Old 05-21-2007, 03:11 AM
Default Safe stroke
82ACAUTOCRAFT With out touching the block for any kind of clearance problems the 428 crank works fine at 3.98. With a little work in a couple of small spots, the 4.25 stroke. You will have to look at the rod end clearances. This is with BBC rods. You could maybe fit a 4.375 with some more work, but the guys don't like running over square motors. A 484 is a nice motor. What are you looking for? 600 hp or 600 of torque? I am a tork fan with a low max rpm of 62-6500 rpm. I don't like rpms in the 7,000's range. Too many large things in the block spinning at high rates of speed with alot force. This is just me. Rick L.
Old 05-21-2007, 07:46 PM
Keith stroked my original 427 block to 482. It dyno'd at 580hp with the original cast iron heads and original medium riser 2x4 intake. I am dropping it in the car this weekend so in a few weeks I hope to give a report on how fun it is to drive!
