Old 05-16-2007, 07:22 PM
Default Superformance Sohc 427
Is it possible to put one of these in 427 sohc in a superformance with some mods.
Old 05-16-2007, 08:44 PM
Cobra Make, Engine: ERA #726 427 SOHC
Talking
I have one going in an ERA, not sure on the Superformance.
Steve
Old 05-16-2007, 10:15 PM
Banned
I think there might be one or two out there...I recall seeing it somewhere. For the cost and effort though, you'd get just as much "wow" factor by spending less money on a quad of Webers on top of an FE. If you're thinking about one of those SOHC kits on the other thread, I have to think that after all the machining, getting a crank, rods and pistons, grinding the cams, and then adding distributor, carbs, custom headers, starter, etc., you will be deep into $20K before you can even turn the key.
-Dean
Old 05-17-2007, 05:51 AM
Cobra Make, Engine: TBD, other is 67 Mustang GTA 390 Convertible w/air,
Send a message via Skype™ to fostereast
Default SOHC in Superformance
You would have to modify the footboxes and steering system, possibly other things as well; ERA knows the mods necessary and can deliver a kit all set up. I do not know if anyone has sorted out the requirements for an SOHC in a Superformance.
Old 05-17-2007, 06:01 AM
Stentor's Avatar
Cobra Make, Engine: CSX 4000; Shelby aluminum FE with 58mm IDAs
Default Call Dennis Olthoff
If anybody would know the answer to this, it would be Dennis Olthoff.
Here's his website
http://www.olthoff-racing.com/
He's a guru when it comes to SPF cars.
Old 05-17-2007, 10:19 AM
Woodz428's Avatar
Cobra Make, Engine: Coupe,Blue w/white stripes SB; Roadster, Blue w/white stripes BB w/2-4s; SPF installer/Hot Rod-Custom Car builder
It's my understanding that the newer # SPFs have been modified to allow installation of the 4 valve Mod motor. If I'm not mistaken that lump of stuff is bigger in every dimension, except maybe length, than the SOHC engine.Soooo... I would think you could fit one in a later SPF with less issues.
WDZ
Rate This Thread:
