Old 05-20-2007, 08:06 PM
priobe's Avatar
Default FE MSD Spring combo
Can someone please post what spring combo I should use with a 427 SO running webers?
I contacted MSD and they recommended 2 blue springs with a black stop bushing. The tech did not seem to sure.
Please help.
Old 05-21-2007, 06:41 AM
priobe's Avatar
Can someone please help?
Old 05-21-2007, 06:47 AM
wizard's Avatar
Cobra Make, Engine: West Coast 460, Performer Cam & Intake, Edelbrock 750cfm Carb
Send your phone number to wzzard@alltel.net. I'll try and explain the basics. It's a little more complicated than trying to establish a standard setup. I'm around all day.
"Nobody gets to see the Wizard. Not Nobody. Not Nohow.
Old 05-21-2007, 06:48 AM
wizard's Avatar
PS 2 blue springs and black stop cam sound like a good starting point.
Old 05-21-2007, 06:56 AM
priobe's Avatar
Thanks numbers are sent to email
Old 05-21-2007, 07:24 AM
wizard's Avatar
For other watching, the black cam will give 18 deg total advance. The blue springs will bring that in around 2600 rpm. If intitial timing is 18 deg, this means that 36 deg will occur at about 2600 rpm. I think this is a good starting point to the safe side. I've heard 38 deg at 2400 rpm for a lot of engines is about the limit. You have to be careful with detonation which can really ruin your day.
Of course factors such as cam profile, octane rating etc will all have an effect on where these setting should be and it will take some experimentation or even better if you can get engine dyno tuned.
Good talkin' to you Priobe.
Old 05-21-2007, 08:17 AM
priobe's Avatar
Wizard,
likewise
Thank you for the helpful info.
