Old 05-28-2007, 05:21 PM
SJK2's Avatar
Cobra Make, Engine: SPF#2189
Question How Much Mist/oil ??
How Much Mist/oil coming out of a 427 FE breather@ idle is considered "normal" ie: This breather:
Steve
Old 05-28-2007, 08:50 PM
wtm442's Avatar
Beam Me Up Scottie
None is normal if everything is set up correctly and working.
Warren
Old 05-31-2007, 11:09 AM
When I shift at 7,000 rpm I tend to see some misting!!
Old 05-31-2007, 11:56 AM
If you have a PCV, you shouldn't see any.
Old 05-31-2007, 01:29 PM
RedCSX1's Avatar
Default I saw a lot more using that breather than
using the oil return can set up I currently have. Should have a PVC as well.
Morgan LeBlanc
Fresno CA
Old 05-31-2007, 04:06 PM
tmareina's Avatar
Cobra Make, Engine: Unique #9159 428 FE 614HP by FE Specialties
I have the same breather...614HP....no misting or any residue out of any of my breathers.
Tom
Old 05-31-2007, 07:11 PM
How new is the engine SJK? Rings not seated?
Old 06-01-2007, 06:40 AM
SJK2's Avatar
250 miles........
Steve
Old 06-01-2007, 06:44 AM
Was it broken in on a dyno? If not, your rings may not be seated just yet....you could give it some good hard driving time and see what comes of it. Otherwise, it may be wise to do a compression check (also read your plugs) and see if you have a ring that's not doing its job.
Old 06-01-2007, 08:46 AM
SJK2's Avatar
Ok thanks will try all above, also it was run on a dyno so i "assume" broken in.....
Steve
Old 06-01-2007, 08:50 AM
It probably depends on how much running it did. Some shops will fire the engine up and let it run with a load on it for 20-30 minutes then make 10-12 pulls on it.
