Old 07-10-2007, 01:29 PM
Default Valve covers hitting master cylnder ?
My valve covers on my 427 side oiler are hitting my master cylnder for the brakes. The way I see it I have a couple of options:
- modify the pedal assembly and move the master cylnder toward fender 1" or so
- notch valve cover (I do not want to do)
Am I missing something ?
If they made a dual reservoir master cylnder for a disc/drum set-up that only had the exits on the fender side then I would be clear.
Any ideas would be appreciated.
Old 07-10-2007, 03:19 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Corvette master for four wheel disc?
Old 07-10-2007, 06:23 PM
Ibr8k4vetts's Avatar
What kind valve covers and what kind of car might help
Mike Z
Old 07-11-2007, 05:20 AM
I have the original Shelby pent roof valve covers and the car is a 67' Fairlane. The engine is an original 427 side oiler. I talked to Wilwood and they said they do have a Chrylser Master Cylnder that only exits on the fender side but it was 1.125 bore which they thought was a little big for a disc/drum application.
Thanks.
Old 07-11-2007, 05:34 AM
For a '67 Fairlane, you probably want the factory style valve covers which have a relieved or flattened or notched (however you want to refer to it) valve cover on the driver's side for just this reason.
I believe Master Power Brakes has a smaller diameter master cylinder for that application which might solve your problem. But I'm not sure of that.
Old 07-11-2007, 05:47 AM
Are you running power brakes? I had the same problem with the 427 in my 1967 Mustang. I slipped a washer between the inboard power booster studs and the firewall. The 1/16" "shims" shifted the master cylinder at least 1/2" away from the valve covers.
Old 07-11-2007, 07:25 AM
Power Surge's Avatar
There is a guy on ebay selling FE valve covers, modified for a master. I THINK it might even be DSC. Do a seach under 427 Cobra, that's where I noticed them.
Sal Mennella
Old 07-11-2007, 10:57 AM
I did an EBAY search but I did not see one that claim to be modified for a master cylinder. I saw the Blue Thunder and Cobra 427 covers sold by DSC motorsports.
Do you happen toknow which ones you saw ?
Thanks.
Old 07-11-2007, 02:06 PM
This is what I saw, no idea if it's what you need....
http://cgi.ebay.com/ebaymotors/Ford-...QQcmdZViewItem
Sal Mennella
Old 07-12-2007, 04:55 AM
Thanks. I have emailed DSC Motorsports to try to get some dimensions. They look so close to what I have that it is hard to imagine that they get me the extra 1/2" to 3/4" that I need.
Old 07-12-2007, 05:49 AM
Jerry Clayton's Avatar
the master that has become quite popular for your needs is off a 68 mustang with power front discs/rear drums---dual res/fender side exits---less than $100 new
Jerry
