11-21-2007, 01:19 PM
I am be wrong but I see a couple of things
11-21-2007, 01:26 PM
Are the rockers off set??
Eddytheb Are the adjusters for your rockers all centered?? The picture makes them look like the adjuster are off center and may have not been installed right??  They look like Dove rockers, what is the writing on the rocker face, it's hard to tell. The other thing is are they a full roller rocker or only a tip one.  Thanks for the info Eddy.
11-21-2007, 05:38 PM
Guys this motor will never make it back in my shop. I am doing a new motor (looking for good core right now) for this car. Last month was the two year anniversary to when I hired this engine guy to build me two motors (both for 90k cobra builds) and gave him a $7000.00 deposit. I am winning the case, he wants to keep it out of court, we have a court date but he is a few bucks short but has till Dec 14 or it goes to court.
11-21-2007, 08:23 PM
Il
Originally Posted by RICK LAKE
Enginetime Mark I see a couple of things wrong. 1st the bolts for the rocker shafts are only grade 3.
Actually they are grade 5, you add 2 to the number of marks. I think the factory ones are grade 8. Grade 3 are unmarked in most cases.
WDZ
11-21-2007, 08:35 PM
The rockers in the pictures say Competition Cams.
Sal Mennella
11-22-2007, 12:03 AM
Engine
We can build about any kind of FE engine you want in 6 to 8 weeks and that is with CNC machined heads and block complete of the engine dyno. I do not understand how this kind of stuff happens and how the customer gets hooked up with some of these people. Was he just real cheap on the engine or something. Good luck, Keith
Keith C
11-22-2007, 05:32 AM
Dove made the bodies and stamped them
Power Surge Sal Dove makes alot of rocker bodies for other companies. Last time I was there I saw 2 55 gallon drums full of rocker arms. 1 drum was finished awaiting stamping and the other was getting pin and roller tip. The rockers without roller bodys, IMO Dove makes 80%. Scorpion rockers are made by Dove. I wouldn't be surprised if Comp Cams does the same. Rick L. Sal have a nice holiday. Maybe get to go for a drive today if the weather is nice.
11-22-2007, 05:43 AM
All I wanted was a one hp per cube 390 $7000.00 to the builder $3000.00 + in legal fees two years later I am real unsure about trusting any one to build me the motors I need. I am not sure what to do I have to wait a bit more, I am supposed to get the $2200.00 + in parts back that I supplied (carb flywheel water pump pullies things like that) for him to dyno the motor. Some of these things he was supposed to supply but he didnt. By the way he was supposed to be doing a 514 for the other cobra build I am doing but I never seen a thing other than the intake also two years and counting. My phone number is avalible if you send me a email at eddytheb@rochester.rr.com
11-23-2007, 06:03 AM
MI
I am with Keith on this - as a small shop, it usually takes us between 6 and 12 weeks to assemble an FE - somewhat dependent on vendor parts availability. We're on the phone or computer pretty often throughout the build, and encourage customers to call and check in.
I really hate to see folks getting hooked up with unscrupulous shops. It makes the rest of us look bad.
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
11-23-2007, 07:01 AM
ME
Or it makes the rest of you look really good, as we can all appreciate those of you that do it right the first time!
Replica is not a dirty word.
12-05-2007, 06:50 PM
Can you say what was wrong yet ?
12-05-2007, 07:03 PM
I just got the up date today from my lawyer and I had to sign a few more papers to get things going and we have our first hearing on the 14th if they dont settle first. I will tell all as soon as my lawyer says it ok, for now if any one is looking to have a motor done in the western new york area email me first
12-05-2007, 09:37 PM
NM
Cobra Make, Engine: Cardiac, 428 FE
I have a set of Harland Sharp roller rockers and they don't have those stinkin spring things that are supposed to keep the rockers on top of the valve stem. There are billet aluminum spacers between the rockers on mine so they don't slip off the valve stem like yours did. They are shimmed to fit properly. I think there are other mfgs roller rockers that are built that way too.
The combination of revs and valve springs allow some lateral freedom that can allow those spring centering things to let the rocker move off the valve stem. That's what I see in your picture. It may have bent the pushrod too in it's trip off to the side.
Here's the Summit part that I have:
http://store.summitracing.com/partde...K&autoview=sku
Cheap valve gear is poor economy.
Paul
12-06-2007, 05:25 AM
Cobra Make, Engine: none
So what did you decide was really wrong with the valves and rockers.Ive seen that happen on a 3406 cat when the rockers were left loose or the valve head bent(might have been a stuck guide there).I saw it on a VW once because the valves were set way wrong.
01-14-2008, 06:12 PM
Just wondering what was the trouble ?
