Old 07-31-2007, 04:54 AM
Default Thermostat Temperature ?
I am trying to select the correct thermostat temperature for my 427 side oiler that I have installed in a 67' Fairlane. I have a aluminum radiator from Howes Racing and I am planning Spal dual 11" electric fans. The car is primiraly for street use though Keith Craft did do a nice job on the engine giving it a healthy 580hp. It seems like there a several options for cut on and cut off temperatures and any opinions would be appreciated.
Old 07-31-2007, 05:16 AM
I've had a Spal fan integrated with my aluminum radiator and 427 s.o. for several years. I use the Painless Fan-Thom relay with electric thermostat, part #30103. The turn-on temp is 185 degrees, the turn-off temp is 170.
Try that one. Painless offers several other temp on /temp off electric thermostats if you decide you want a different range. Their website posts good descriptions and pictures of this set-up.
Old 07-31-2007, 05:48 AM
Thanks for the quick reply.
Can anyone offer a recomendation of where to buy a good quality thermostat housing for the 427 side oiler ? I have heard that the one from Summit or Jegs may not seal to the factory intake that well. I have an original 2x4 medium riser intake and I would like a nice thermostat housing.
Thanks.
Old 07-31-2007, 06:21 AM
CJ428CJ's Avatar
Cobra Make, Engine: ERA #629, BBM Side Oiler Block, 482ci, Richmond 5 speed
For a nice thermostat housing, try here: http://www.robbmcperformance.com/pro...stat_ford.html
Chris
Old 07-31-2007, 08:00 AM
Nantucket427's Avatar
Cobra Make, Engine: Superformance#1325, Miller Machine FE
Default What heads are you using?
I run a 185 in my FE with aluminum heads. With cast iron heads, I didn't run a thermostat at all.
Everything has a downside, so dwell on the positives. Find humor in the tough times.
Old 07-31-2007, 09:18 AM
I have factory cast iron medium riser heads.
Old 07-31-2007, 11:40 AM
Cobra Make, Engine: shellvalley 428 ford
Griffin told me to use a 180 degree stat and green antifreeze. Since you have a Howes radiator I would suggest calling them and getting their opinion.
Byron
