February 2026
Old 08-03-2007, 12:38 PM
Cobra Make, Engine: Shell Valley, '67 Cobra, 1966 427 sideoiler, 2x4s, w/NASCAR toploader
Default Noisy Starter
Definitely not normal. Possibly one or two teeth missing from the starter drive gear, starter bearings shot and making noise, or hopefully not...missing teeth on the flywheel or the flexplate if it is an automatic. It is probably within the starter itself. Pull it and take it to O'reillys, Autozone, etc. and they will test it on their machine to see if it makes the same noise there. You didn't indicate how old the starter was, or the engine either. Considering the relatively low cost of a replacement starter and drive, I would probably just replace the entire thing so as to avoid messing around trying to decide it it is the drive gear, bearings, etc.
What kind of noise is it? Does it just grind continually or does it sound like it rotates, then skips and rotates again? After you pull it, examine the teeth on the drive to check the wear pattern and to see if it is still good.
When did the noise start? If it was working fine before and just now is making noise, replace it for a hundred bucks or so and be done with it.
Rate This Thread:
