November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 08-21-2007, 02:36 PM
DougD's Avatar
Cobra Make, Engine: Sold my beloved Shelby CSX 4068, Gessford 427 Ford
Default Help needed with fuel pressure regulator
I'm using a Holley mechanical fuel pump with the stock-type 427 hard fuel lines and stock filter leading to a fuel log and a single Holley. I'd like to put a fuel pressure regulator between the log and the hard line coming from the filter. My problem is I can't seem to find a regulator that mounts in-line. Most I have seen have the inlet/outlet ports at 90 degrees from each other.
Can anyone recommend a regulator to mount there?
Has anyone else done this?
CSX4068, '69 Bronco, '70 BOSS 302, '87 Mustang GT, '08 Roush Trak Pak
Old 08-22-2007, 05:41 AM
Default Why Doug?
Doug D, what's the problem, and why do you want to mount a pressure regulator there? Your fuel pump should put out 6-8psi with the car running. Do you have a gauge between the pump and carb? Ir you are running a double feed carb you can get a line with a gauge built on. The regulators are more for electric fuel pumps that run at a high pressure and more volume. Regulators are mounted on the inner fenderwell not the motor, with 2 lines going to the carb bowls. Some even have a fuel return line back to the tank. Hope this helps, If you are having a running problem you may need a carb adjustment. Rick L.
Old 08-22-2007, 09:09 AM
danc30's Avatar
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
Take your pick. Here are a few on Summit.
http://store.summitracing.com/egnsea...DS=1&N=700+115
Old 08-22-2007, 11:55 AM
DougD's Avatar
Rick
I want to mount it there because there's room for it there. I'm using a stock fuel system and would like to keep all the components I already have. I have twin electric pumps in the trunk and a Holley HP mechanical pump.
My fuel pressure gauge is in the dash.
There are plenty of regulators out there for 4-9 psi. I'm looking for one with the inlet and outlet ports in line vs at 90 degrees to each other.
danc30
Summit was the first place I looked. No 4-9 psi models there with the inlet/outlet ports in line.
