Old 10-04-2007, 04:23 AM
Cobra Make, Engine: shell valley,63 427,alum. heads,everything roller
Default 427 heating problems
I took out my thermostat last night drove car,temp.stayed at 185 degrees idling and at 55 miles an hour.Thermostat must be restricting water flow.Guess I need to find a high flow thermostat,what type and brand recmmended?
Old 10-04-2007, 04:49 AM
Clois Harlan's Avatar
Drill a 1/4" hole in the top portion of your thermostat and you should be fine. NAPA has always worked well for me. I think I use one out of a 1968 440 Dodge Charger.
Clois
"Let's roll"
"Be part of Something Good
Old 10-04-2007, 06:00 AM
Cobra Make, Engine: Shell Valley, '67 Cobra, 1966 427 sideoiler, 2x4s, w/NASCAR toploader
Default Thermostat
Cobra Valley makes a special high flow thermostat for the FE. It has a larger flow-through area and is much sturdier than any after market piece I have seen. Check them out on their website at: www.cobravalley.com
I gave the incorrect url...sorry. Try this one
http://performanceunlimited.com/cobravalley/
