Old 11-01-2007, 05:36 AM
Cobra Make, Engine: EM 427SC body, chassis, suspension , my design, 427SO, toploader, shaft drive fan,road race pan, Dove heads, Comp. cam,
Default FE Head Gaskets
Has anyone used the " Cometic " brand head gasket in their 427 engine ?
This is a Viton coated 3 layer S.S. gasket.
Looks like a good design , but expensive.
Looking for long term durabiity on a 427 S.S. iron block / Dove aluminum head engine. ( 10.1 comperssion ) Thanks
Dave
DB
Old 11-01-2007, 05:54 AM
Danr55's Avatar
Dave, I've just finished "working" on my motor and one of the jobs was to replace the head gasket. I used Cometic gaskets thanks to advice from Keith Craft. I was trying to reduce compression on a 351C from 11.5:1. Went with an .080 thick gasket from Cometic. It went together well and seems to be working great. The extra thickness seems to have reduced compression to about 10.7:1. Just finished a 500 mile run to Laughlin and back without incident. I believe that these are worth the money.
Dan in Arizona
CCX3209
Old 11-01-2007, 06:15 AM
Dan, Thanks for the feedback.
I have used FelPro and steel shim in the past, but came across the Cometic recently.
Anyone else with experience withe the Cometic ? Dave
DB
Old 11-01-2007, 06:17 AM
Cobra Make, Engine: ERA #726 427 SOHC
Thumbs up
I use them on my Cammer. No problems so far. They'll make them in any thickness and bore size within reason.
Old 11-01-2007, 07:32 AM
Woodz428's Avatar
Cometic has been around a while with gaskets for bikes and some Foreign machinery. They started making HP gaskets for american V8 engines within the last 15 years or so. They have a pretty good reputation with the 5.0 crowd where, I believe, they initially ventured. I have used them in all types of engines, although not in any FEs. I have had no problems. Many of these were engines of aluminum or a combination of materials.
WDZ
Old 11-01-2007, 09:49 AM
Clois Harlan's Avatar
I am running them on my 427 and to be honest with you I am not sure they are any better than my FelPro gaskets. I have had them on my car for about six months now. They cost more!
Clois
"Let's roll"
"Be part of Something Good
Old 11-01-2007, 10:10 AM
lineslinger's Avatar
What kid of money are you guys talking about for a set?
Old 11-01-2007, 10:30 AM
Danr55's Avatar
Supervee, if you want a real expert opinion, check with Keith Craft. He is the one who recommended them to me.
Dan in Arizona
CCX3209
Old 11-01-2007, 02:09 PM
Lineslinger,
The list price I have seen is $98 each. ( i.e. $200 a set )I am not sure of discounted price.
I will check with Keith Kraft as recommended.
A local engine builder recommended them as well, but I had never seen this particular design.
I had some special issues on one one deck of my S.O. that would cause a FelPro to blow in about 10 minutes running ( not the gasket fault ). But I have run a steel shim gasket for 12 years - no issue.
I am in the process of freshening up the engine ( and I will also correct the block issue ) , and would like to use the best head gaskets. Dave
DB
Old 11-01-2007, 03:49 PM
But, that will affect your quench area, whatever performance effect it will have I don;t know.
