Old 11-23-2007, 04:27 PM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Default fe block hole question?
i bought my 360-390 block bare so i am curious what some of the holes on the pass side of the block are used for?. on the front side of the pass side there is a little pad at the top of the block what is this used for?, and on the pass side near the motormount area there is a hole above the freeze plug what is this hole used for?. any info would be appreciated.
Old 11-23-2007, 05:40 PM
The hole up front was originally used for generator mounting - and was later used to connect the ground cable.
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 11-23-2007, 08:00 PM
thanks barry, that solves one mystery, does any one know what the other hole is for?. also what should be plugged on the drivers side and passangers side pictures would be helpfull for reference.
Old 11-23-2007, 08:18 PM
Woodz428's Avatar
Since you give no casting #s or date of the block, it would probably make more sense for you to post pics of the block with any questions. There are some subtle differences between early and later block, so a pic of yours, would make any replies specificly about your block.
WDZ
Old 11-23-2007, 08:37 PM
the block is a 72 360 block
Old 11-24-2007, 02:45 PM
i found today that the other hole near the freeze plug is like the one at the front of the block, and the other two on the pass side have a 1/4 pipe thread i guss there to drain the block and there is on the drivers side of the block also.
