Old 11-24-2007, 04:20 AM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
Default crankshaft keys for keyway?
where do you buy the keys for the crankshaft?, when i received my rotating assbly they did not come with it. this is my first fe so i am unsure what i need.
Old 11-24-2007, 05:43 AM
Default Lowes
wrench 87 Lowes has all the sizes you need for the crank. look in hardware Rick L.
Old 11-24-2007, 07:44 AM
philminotti's Avatar
Cobra Make, Engine: KMP 736 Street, Pond 482, FAST XFI EFI
For a stroker FE, Scat I assume, the woodruff keys are standard SBC size and the balancer key is 1/4" x 1/4" x 3/4" bar stock. any machine shop can provide that one.
phil
Old 11-24-2007, 09:07 AM
yes it is for a scat steel crankshaft 4.250, i was surprised i did not get it with the rotating assbly, i got one with my eagle crank for my 342.
Old 11-24-2007, 09:41 AM
hope this doesnt sound like a stupid question, but does the bar stock run the length of the cut out on the crankshaft?
Old 11-24-2007, 09:55 AM
The keystock only needs to be as long as the slot in the damper. The Scat does indeed use normal Chevy keys - I buy 'em by the hundred - if you can't find 'em local just call/e-mail and I'll toss a couple in the mail...
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
