Old 02-10-2008, 08:51 AM
Unhappy 390fe Intake manifold ports?
I am almost done putting my 390 back together and I can't get my video camera to work from where I taped the motor so I could keep up with the vacuum hoses and variuos sensors I had to remove. I have 3 ports on the intake, 1 is for a sensor and one for a vacuum tee and not sure about the third. I am not sure which goes where and cant find any pics to help. 2 ports are at the distributor and one at the rear. If any one can help this would be much aprreciated.
Tommy
Old 02-10-2008, 10:44 AM
Can't really say for sure without a picture, but I would venture to say that the ones at the front are for the bypass hose and the water temp sending unit. The one at the rear is probably for a PCV.
Snap a picture and post it. We'll help you figure it out.
Old 02-10-2008, 10:59 AM
Default Here's the Vacuum Diagram for a 1969 390Fe w/ Manual Trans.
Old 02-10-2008, 11:29 AM
Default Shot of the Thermactor System
Here's a shot of the Thermactor system on same Ford FEs. Maybe this will help, but you know, most of us just plug off all the holes in the IM. We run a PCV, or a breather, and that's it.
Old 02-10-2008, 01:54 PM
Thanks for the help. I found out one was for the heater core hose on the front. The other is for a coolant temp sensor. The one on the rear was for vacuum to operate the add-on power brakes the previous owner installed. Had to go to local junkyard and check the only 390 motor the had left in a vehicle.
Tommy
P.S. I need to learn how to post pics because everytime I try they are too large to use.
Old 02-10-2008, 02:04 PM
Name:  390 intake.jpg
this is the front near distributor.
Name:  390 intake#2.jpg
this is the rear
Old 02-10-2008, 03:32 PM
Now if you'd have hooked your distributor advance up to your coolant temp outlet that would have required the ultimate virtual ball-busting!
