February 2026
Old 02-16-2008, 05:05 AM
Cobra Make, Engine: CSX4000, 427
No matter what, you should de-burr the gear on the cam, as I think it may enhance the distributor gear life no matter the material.
If my memory serves me right, the "stock" FE distributor shaft size is something like 0.484" . A 351C/429 shaft size is 0.530" . I believe the gears are the same except for the internal shaft diameter. MSD FE distributors use a 0.530" (429 size) shaft, so that is why you would use a 429 gear on their FE distributor. You need to mic the shaft diameter on your distributor to get the true shaft size, and thus correct gear.
My replacement gear was a press on, and then I had to drill another hole, but, you need to make sure the gear is positioned at a correct distance on the shaft.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
