Like Tree1Likes
Old 03-07-2008, 02:04 PM
hi-tech cobra's Avatar
Cobra Make, Engine: Hi-Tech
Default 580hp. Does that sound right?
I was just informed the engine has been dyno'd and is ready to ship.
They found one of the dyno sheets and said it was 580 hp / 610 tq.
They didn't know if this was the final dyno but does that sounds right? I'm not complaining but I thought this package would make 600+ with no problem.
I know this post is missing key details (dyno sheets will be emailed to me shortly).
But here is what I know:
•crank & rotating assembly
•hp heads
•Edebrock Perf RPM intake
•Quck Fuel 780 vacuum sec. carb
•hi perf rockers
•Crane Hyd. roller lifters
•Comp Cam Hyd. roller cam
Here is all the info I have from Keith on the cam:
"You will be getting a FE hydraulic roller camshaft that is a 33-000-9 core with the following information;
Intake you want a # 3113 lobe number
Exhaust you want a # 3170 lobe number
112 lobe separation with 4 degrees advance ground into the camshaft
Like I said, I'm not complaining and 580hp is way more than my cobra needs. It must be the adrenaline talking.
Rate This Thread:
