Old 03-19-2008, 11:04 AM
hi-tech cobra's Avatar
Cobra Make, Engine: Hi-Tech
Default Blue Thunder Pent-Roof valve covers
After reading about the oil leak problems with the stamped steel chrome pent-roof valve covers, I decided to give the Blue Thunder Pent-Roof cast alum ones a whirl.
Anyone have these? I ordered mine from http://www.dscmotorsport.com.
Old 03-19-2008, 11:44 AM
I have owned a set. They wouldn't clear my Erson rocker arm setup.
Old 03-19-2008, 11:47 AM
That's bad. I better call before they ship!
Old 03-19-2008, 11:50 AM
Do the regular chrome pent-roof valve covers clear the Erson rocker set up?
Old 03-19-2008, 11:52 AM
Cobra Make, Engine: Cutting Edge, Boss 429
Oh I think you will have plenty of time before they ship
Old 03-19-2008, 11:56 AM
rokndad's Avatar
Cobra Make, Engine: CSX 4758, CSX 381 Keith Craft 482 w/ Weber 48 IDA's
I bought the polished Shelby FE covers from them and everything clears perfectly. And not one drop of leakage! The chrome stamped steel FE covers I had before leaked like sieves. Rubber gaskets. On the cast covers I used Fel Pro rubber impregnated cork gaskets from Summit, sealed completely to the new covers with gray RTV, let sit overnight, and bolted them up.
Since it appears you also have a KC 482, you must have the same heads and pretty much the same valve train as I do. Call Keith first. I seemed to luck out.
Not sure. They clear T&D, so probably.
The Ford Racing valve covers clear easily, if that helps.
You could always return them. I didn't mess with thick valve cover gaskets or anything...but they wouldn't set down on the head for me.
Old 03-19-2008, 11:53 AM
BTW, which ones did you buy? They have a regular set and a comp set.
Old 03-19-2008, 11:55 AM
Boss.....LOL
That was funny to us that know what you're talking about....
BTW Hi Tech....check out my webpage, click on the 428FE page and you can see the Ford Racing covers.
Old 03-19-2008, 11:57 AM
I couldn't help myself. Low hanging fruit
Old 03-19-2008, 12:30 PM
Here are the ones I ordered.
http://www.dscmotorsport.com/asp/Pro...to.asp?ID=1038
Old 03-19-2008, 12:41 PM
Originally Posted by hi-tech cobra View Post
Let us know when they arrive.
Old 03-19-2008, 12:44 PM
rokndad's Avatar
I don't know. That little indentation for bolt clearance on the top side with the three bolt holes looks problematic. The finned cast ones didn't have that much indentation.
I like the cleaner look of the ones you're ordering better, but knew the ones I ordered would fit since I had seen them on the engine earlier. Keep us posted when you get them.
Old 03-19-2008, 01:32 PM
You guys think DSC won't ship? Any words of warning I need to know about? PM me. Thanks!
Old 03-19-2008, 04:46 PM
ST's Avatar
ST ST is offline
Cobra Make, Engine: Kirkham#182/Shelby 496c.i.
Been using the Comp covers for a few years now with no problems.http://www.clubcobra.com/photopost/s...9&ppuser=10990
"You can NEVER teach a pig to sing! You'd just be wasting your time and annoying the pig!"
Old 03-19-2008, 05:00 PM
The cast aluminum 427 valve covers I got had to be ground down an 1/8 in the end sides to accomodate the dove set up ,figured it was typical .What was the erson clearence issues , at the ends also ?
Old 03-19-2008, 06:29 PM
John, it's been a couple years, but I think you're right.
Old 03-19-2008, 06:41 PM
So they will fit, I'll just need to clearance a bit?
Or do I need to specify the Comp version? What's the difference between the two?
Old 03-19-2008, 06:42 PM
I think the non-comp ones will need clearanced.
The comp versions will probably fit. They also have a couple holes per valve cover for PCV valves, breathers, oil fill, etc.
Old 03-19-2008, 07:21 PM
Just got an email from Dennis, he said my covers shipped out today (pretty fast).
He said I might need to grind a little. I will post an update when the engine gets here.
