Old 04-22-2008, 07:31 PM
hi-tech cobra's Avatar
Cobra Make, Engine: Hi-Tech
Got the engine mounts from Tim G. I think they are Anchor. I can't seem to find this bolt ring for the flywheel...because I don't know what it is called or where to get it!
Old 04-22-2008, 07:32 PM
If you don't find it, don't sweat it. The ARP bolts have a huge head on them. Also, the Anchor mounts are rubber, I'd go with a rubber trans mount.
Old 04-22-2008, 07:51 PM
I will call Fidanza in the morning to see if the bolt ring in necessary.
What are the torque specs for the flywheel and the pressure plate? Is there a link with those numbers?
Old 04-22-2008, 07:52 PM
I used an aluminum Fidanza wheel on my 428FE....I didn't use a ring.
Did you buy ARP fasteners? The specs will be on the box.
Old 04-22-2008, 07:54 PM
How does 70 ft lbs. on the flywheel and 30 ft lbs. on the pp sound?
Old 04-22-2008, 07:56 PM
blykins,
I just saw on Muscle Car's website a Fidanza alum FW with no bolt ring. I'm thinking it won't be necessary with the ARP bolts. I will consult with Fidanza about that tomorrow.
Old 04-22-2008, 08:00 PM
I'm sure you'll be fine without it. Your torque specs sound close....I was thinking 65/25...but like I said, the specs will be on the package.
Do you have a new set of muffler bearings?
Old 04-22-2008, 09:51 PM
Sminor's Avatar
Cobra Make, Engine: Shell Valley Roadster,428FE, 2X4's; 1966 GT 350 Clone; 1968 Shelby GT-350
Hey Brent,
It sounds like High-Tech is about to pull his hair out and you're messing with him about muffler bearings..........You should be ashamed ! I'm sure he keeps spare muffler bearings in the same drawer as his left-handed adjustable wrenches.........
steve
Old 04-22-2008, 10:13 PM
xlr8or's Avatar
He's probably low on headlight fluid too.
Old 04-22-2008, 10:19 PM
Cobra Make, Engine: VSE alum. frame, FFR carbonfiber body (under construction)
I was going to say torque wrench but it sounds like you thought of that.
Old 04-23-2008, 12:01 AM
John, I have a bellhousing alignment tool IF it will bolt-up to your crankshaft; If not, dial indicator and base.
Old 04-23-2008, 05:31 AM
Default The most important stuff!!!!
hi tech cobra The most important thing is Beer, Coke Cola, and steaks. They get the reward after the job is done. You may want to add bolts to the motor mounts if they are rubber. This will stop them from splitting under hard driving and still gives the frame isolation from the motor vibs. If the frame is painted you might want to tape and paper off the rest from burn spots when welding. A electric level will help with the perfect leveling of the mounts. This is up to you guys but some of the cobras have the motor sitting 1" to the right for balance of the car. I think you have the rest covered. Good luck, get a couple of pictures. I hoping you are going to have the car on jack stands, try and have the frame level as possible, this make the whole job easier. Rick L
Last edited by RICK LAKE; 04-23-2008 at 05:33 AM.. Reason: Forgot Wet towels when welding helps save the paint from bubbling off the frame
  #33 (permalink)
Old 04-23-2008, 06:12 AM
Default New iStart from Apple!
blykins,
I have the muffler bearings, man were they hard to find. Finally found them at a garage sale late last night...guy said they were brand new and fit my application. He seemed to know what he was talking about so I picked up a couple extras. Let me know if you need some.
I also decided to go with the new iStart from Apple. It does everything an iPhone does, play your favorite "Cars" tune, call your wife and tell her the motor only cost $5K, and download the latest Hooters girl calender.
Here's a pic!
  #34 (permalink)
Old 04-23-2008, 06:16 AM
LOL That is awesome.....
  #35 (permalink)
Old 04-23-2008, 06:25 AM
Ital-cobra's Avatar
Cobra Make, Engine: Emerson cobra, 460 550HP
High tech...65/25 if you torque 30lbs on the p/p plate you'll snap the bolts....snaped two yesterday not fun...grade 8 bolts too...now I'm torqued at 25lbs no problems.
Joseph
The desire for imaginary benefits often involves the loss of present day blessings.
  #36 (permalink)
Old 04-23-2008, 06:01 PM
Running out of time...anything else you can think of?
  #37 (permalink)
Old 04-23-2008, 11:42 PM
Note to self:
Brake Cleaner
Blue Locktight
1/2" round steel tube
ARP bolts in office
