Old 04-22-2008, 05:52 PM
thorconstr's Avatar
Cobra Make, Engine: ERA 427" 351W
Default 427 solid rollers
Have any of you guys used a bigger bore roller solid lifter in a 427 SO stroker motor? What make?
Al W.
Old 04-22-2008, 05:59 PM
You mean a larger diameter lifter body?
Old 04-22-2008, 06:32 PM
thorconstr's Avatar
Sorry, yes!
Al W.
Old 04-22-2008, 06:35 PM
Can't say that I have. Why do you ask?
Old 04-22-2008, 06:51 PM
thorconstr's Avatar
I figure that a larger diameter would give you a larger roller area, and more bearing area. It should give you better bearing life!
Al W.
Old 04-23-2008, 01:18 AM
Default Larger diameter lifters
We have used the .903 and .930 diameter lifters in our race FE engines. We use Jesel lifters in most of these cases but they are a little pricey for a street engine at 2200.00 dollars. The main thing to look at is the spring pressure, lift and rpm of the engine. There are several different quality .875 lifters out there that work well up to about 300lbs on the seat and 800 open. We started see problems when we went to 400 lbs on the seat and 1000 lbs open on some of the 2000HP blower and turbo engines we were doing. The regular .875 lifter would only live about 20 to 25 passes. Like evrything else durability and quality come with a price. Good luck, Keith Craft
Keith C
