Old 05-08-2008, 08:04 AM
Cobra Make, Engine: currently Cobra-less
Default 220° oil temp, good or too warm?
hello all
I am wondering about proper operating temperature of my FE. When completely warmed up, the water temp is generally right around 200° and the oil temp 220°. No oil cooler. Is that acceptable or too warm? I have a 190 or 195° T/stat in there and am considering changing it to a 180°.
From reading other posts, it appears FE's generally like to run a bit on the warm side.
What are your thoughts?
thanks
when in doubt, floor it
Old 05-08-2008, 08:11 AM
Jerry Clayton's Avatar
oil temps should always be high enough to boil out condensation---if you use too cold of a h2o stat you will probably increase condensation ---I would rather my oil be upwards to 240
Of course all this also is effected by where your temp guage sender is mounted
Old 05-08-2008, 04:10 PM
427 S/O's Avatar
86, that's a wee bit high, use the mopar 190 stat'. works very well for me.
Perry
Old 05-08-2008, 04:23 PM
I wish mine would run at 220 degrees. I'm with Jerry and 427 S/O, 220-240 is a fine oil temp, but 200 is a wee bit high for the coolant.
Ken
Old 05-08-2008, 04:51 PM
N2VENOM's Avatar
Cobra Make, Engine: Kirkham KMP500 LeMans- Roush 451 Shelby block; KMP Flip-top with cammer: KMP 289 Bronze under construction.
My 427/451 Shelby/Roush H20 temp runs 175-190 all day long with the oil temp around 220. Darren
Old 09-01-2008, 08:21 PM
Spoooky's Avatar
Cobra Make, Engine: 65' SPF (511 CID) FE 427 Alum Block Shelby /Roush 600hp-625fpt sideoiler
Mine runs at about 210 F oil and 195 F coolant. I'm in Phoenix and summer day can be 110 F +. They like to run a little warmer..
