Old 05-08-2008, 09:43 PM
Brent Mills's Avatar
Administrator
Default Brent's Keith Craft 482FE buildup
Well, I'm in the process of building an RCR GT MKIV, and I asked the folks at http://www.keithcraft.com/ to build something "appropriate" for such a ride. We settled on a Shelby block, 482, which ended up on the dyno with some impressive numbers. 594HP and 605TQ. Uhmmm...that oughta do!
I asked them to take some pictures and give me some captions, as I wanted to document the build of the car, and I have always wondered about what it takes to build these puppies. I know it's not rocket science, but to many of us, it seems like it. Anyways, below you'll find some pictures and descriptions of the process.
Boring, decking, and blueprinting done on RMC Machine
Here we are line honing the mains
Honing the block with torque plates
Honing bar inside block
Rotating assembly for engine build
Custom Keith Craft Diamond Pistons
Scat I-Beam 6.700 Connecting Rods
Pistons, pins, and rods before assembly
Crankshaft being balanced with correct bob weights
Heads being CNC ported in 5-axix CNC machine
Bare Edelbrock CNC ported Castings
Chamber and valve job on Edelbrock CNC castings
Exhaust ports on Edelbrock Castings
Shelby block with head and main studs, checking block for crankshaft rotation.
Shortblock with lifters and timing set installed.
Shortblock with damper and oil pan.
Long block ready for valvetrain installation.
Moly on the pushrods to keep from coming off lifter during assembly.
Engine on SF-902 for Dyno Test and Tune
Dyno #'s!
Old 05-08-2008, 10:01 PM
wtm442's Avatar
Beam Me Up Scottie
Saweeeeeeeeeeeeeeeeeeeeeeet
Warren
Old 05-08-2008, 10:03 PM
Chaplin's Avatar
Brent-
Nice pics. What cam is in that? That looks like it is going to be a real nice motor- makes peak hp below 6k and 600ft/lbs of torque at 4300! Any idea what kind of torque it made lower in the rpm range? If it is making 600 at 4300, I would have to think it is over 400 by 3000 rpm. Hope you have a lot of money for tires!
Replica is not a dirty word.
Old 05-08-2008, 10:14 PM
xlr8or's Avatar
Hope you have lots of money for a transaxle.
Brent that is going to be awesome.
Old 05-08-2008, 10:43 PM
Administrator
Yeah, believe me, I'm not going to be doing any stand still burnouts. The 930 transaxles are stout, but....I'll need to be careful.
Old 05-09-2008, 03:36 AM
undy's Avatar
Brent,
I know you'll love the engine. Keith's Pond 482 that he built for me is literally amazing, tremedous power, Z-E-R-O oil consumption/blow-by, no drips, leaks or runs. 2K mile on the oil and it's still so light amber in color that I have to put on the reading glasses to read it on the dip stick.
What's the specs on the Comp Cams custom hydraulic roller?
Dave
Too many toys?? never!
Old 05-09-2008, 04:33 AM
Naumoff's Avatar
Thanks for sharing Brent.
What does the engine weigh?
Old 05-09-2008, 06:01 AM
Dwight's Avatar
Smile GT 40 motor
Thanks for the story and pics!
I hope you post pictures of your GT 40 build.
Dwight
Old 05-09-2008, 08:38 AM
Keiths machining equipment is incredible!
Not like the old days.......
B. Ewing
Old 05-09-2008, 08:46 AM
Originally Posted by undy View Post
Brent,
Dave
Great motor and man does it run, but it leaks like crazy. Maybe just oil the engine doesn't like and spits out.
B. Ewing
Old 05-09-2008, 11:58 AM
RedCSX1's Avatar
Default Morgan
Brent, Thats awesome. This is going to be some car. Of course all tax deductible right! Keith the build pics of the Shelby FE are great.
Morgan LeBlanc
Fresno CA
Old 05-09-2008, 12:06 PM
Naumoff's Avatar
Brent,
You know the Mk IVs ran 2x4s inside a closed air box? That single four barrel just won't due.
Old 05-09-2008, 12:09 PM
damdfw's Avatar
Cobra Make, Engine: CSX 4973
Is it wrong that I feel aroused after looking at those pictures?
Old 05-09-2008, 01:38 PM
Administrator
Originally Posted by Naumoff View Post
Brent,
Some had single some had dual. Both ways were in enclosed box and I'll be fabbing that up.
Old 05-09-2008, 01:57 PM
Naumoff's Avatar
Cool Bent.
All the picks I have of the 1967 Mk IVs have 2x4s. I know you have done your homework.
Old 05-09-2008, 08:06 PM
Congrats on the engine!
The pictures of Keith Crafts shop deserve compliments too. What a nice set up. No wonder Keith has so many happy customers who compliment him all the time. I'd like to take a vacation there! I need a napkin to wipe up all the drool.
Old 05-10-2008, 01:14 AM
Default Sweet Motor Brent
Brent Mills Brent that's one strong motor you have. You you going to use a drysump in the car? for ground clearance? You think the cobr was a handful, wait until you get this hooked up in a GT. You you getting the parachute and diapher options? You know that with the right gearing you are looking in the 220mph range.. What is the torque rating on the 930 box? You might be pushing the limit. I will thinking that a TWM setup of 58's would setthat motor off really nice. (see other thread from SF Firedog on 511 motor) Rick L.
Old 05-10-2008, 02:04 AM
Jac Mac's Avatar
Smile
Rick, the same thought about the pan crossed my mind although the pic gives a distorted view of the pan depth. FE's sit nose high in GT to the tune of around 3° so it may be OK.
Two Holleys are the 'right' look for induction , but hell who cares, damn thing will be that quick nobody will be able to keep up to see under the hood/clip.
Jac Mac
Old 05-10-2008, 05:18 AM
Naumoff's Avatar
With the custom air box he has to build like on the originals I have seen it really doesn't matter.
The looks lf the Mk IV has grown on me real quick.
I like it better than the Mk II now.
Old 05-10-2008, 11:11 AM
Congrats Brent, I have basically the same engine coming as well.
Your pics are great. (shows me what mine looks like)
Kieth has quite the setup over there.
