Old 08-12-2008, 07:40 PM
Cobra Make, Engine: SPF #373,Shelby FE Alum Block #077, 488 stroker, Tunnel Port, Dual-TMP DP Holleys
Default FE Tunnel Port EFI
Does anyone know of a company that has develped a Weber look-alike EFI that will mate to Tunnel Port heads. Thanks for any help.
Old 08-12-2008, 08:51 PM
SoTxButler's Avatar
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
You might want to check with Paul Swartz at swartzracingmanifolds.com. He built a 3 piece billet manifold for my high riser FE. He can probably modify the head plates if you can talk him into it. Good Luck. Tell him Russ sent you. A couple of pics for you to see his work.
Russ
Old 08-12-2008, 10:52 PM
RedCSX1's Avatar
WOW, Very nice.
Morgan LeBlanc
Fresno CA
Old 08-13-2008, 06:07 PM
It will take probably more than just plate change. The plates would need to be thicker perhaps and would need to have TP tubes would need to be fashioned in so I would think the runner may even need to be bigger,certainly round. I would have to send him my mainforld to pull dimensions from. An even better way would be to send him my block and heads too. I realy don't have the energy anymore.
Now if I had the money to order a new SPF GT40 and build another alum FE I could find the energy real quick!
I really would like to find a piece that was totally sorted out in terms of fit. If off just a hair then the pushrods might rub or oil leak out the back.
Old 08-14-2008, 07:29 AM
Ken Oikawa's Avatar
Default Here's my setup...
Hilborn mechanical converted EFI
Old 08-15-2008, 05:23 PM
Interesting approach. Looks like the runners from the Ford TP intake were cut at the base and rotated up and welded in. Then flanged and bolted to a Weber style plate.
Old 08-15-2008, 05:34 PM
Cobra Make, Engine: Cutting Edge, Boss 429
Beautiful piece Russ
Old 08-15-2008, 06:01 PM
SoTxButler's Avatar
bossCER
That 429 is sure purdy!!!!
Russ
Russ
