Old 09-26-2008, 01:44 PM
priobe's Avatar
Default Looking for ARP # for Thrust Plate
Hello All,
I am looking for the bolt for the thrust plate on a 390 - 427 FE.
I tried calling ARP for the bolt but they do not have one for that size.
What have you guys been using?
Old 09-26-2008, 01:55 PM
Call one of the engine builders, KC, Doug Garifo, Barry R. They have them. I bought mine from KC. They have the heads milled down.
Old 09-26-2008, 02:47 PM
Actually a normal 7/16 bolt will clear many common timing sprockets without trimming. Alternately some of the motorcycle supply guys have 7/16 button head allen screw that work quite well - some are a touch long but are easily cut to length.
Survival Motorsports
"I can do that....."
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
Old 09-26-2008, 03:04 PM
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
there is a company called headbolts.com wich is located in portsmouth, new hampshire that sells them, they have a lot of bolts for the fe.
Old 09-26-2008, 03:35 PM
convincor's Avatar
ARP's out of stock http://headbolts.com/fordfe.html?gcl...FQSPFQod5Wa0Ew
But they do show the "Kit" being availible in ARP
They also have them in a DuraBond kit http://headbolts.com/durabond-finishing-kits.html
DSC list the ARP's http://www.dscmotorsport.com/Engine/index.htm
02 Super Duty 7.3L
Old 09-29-2008, 07:01 AM
The Durabond kit is junk. They come with normal hex head bolts, and the 2 piece fuel pump eccentric they provide is so loose you'de be scared to put it in a lawn mower.
