01-18-2009, 08:06 PM
OK
Cobra Make, Engine: FFR MK III,462 FE/TKO 600, IRS w/3.27
Edelbrock FE timing cover
Is anyone familiar with an older (I'm assuming) Edelbrock alum timing cover for a FE? I'm watching one on ebay; cast alum that has been polished. Must have been made by Edelbrock some time back, can't find out any other relevant info. Anybody ever seen one? If you look at it on ebay, any ideas as to the cover intended to cover the end of the camshaft? for a cam button or ???
thanks!!
http://cgi.ebay.com/ws/eBayISAPI.dll...MEBI:IT&ih=013
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
01-18-2009, 08:45 PM
Ebay link not working. ---you have an item number >?
01-18-2009, 08:47 PM
That is isntended to mount a mechanical fuel injection pump driven by the cam.
01-18-2009, 08:48 PM
the link you posted doesn't seem to work but from what your describing it sounds like a cover for mechanical fuel injection the fuel pump was driven by the camshaft, hilborn made them, algon made them, to name a few. there is no cover to cover the hole, some were even machined flat on the face to use a motor plate.
Fred
01-19-2009, 03:05 PM
OK
Ooops, sorry the ebay link didn't work, I should've checked it &/or listed the ebay item number.
Anyway, Fred and Rick, thanks for the input; makes sense that it would be for a cam driven FI pump, which would've been used w/o a water pump on a drag strip car. Even if I were to make a cover plate for the hole over the cam, its probably not feasible for a street driven vehicle using a conventional water pump.
thanks again guys!
Wideglidejoe
Painted Nov 2015
01-19-2009, 03:08 PM
OK
ebay item # is 230319860515.
I'd appreciate any thoughts if this cover could be used under a conventional Edel alum water pump if a blank cover was installed over the cam hole.
thanks!!
Wideglidejoe
Painted Nov 2015
01-19-2009, 04:11 PM
Ne.
Are you wanting a stock FE cover ?
I have one if you need it.
It's a pain trying to get it centered so it does not leak. (Just thought I would throw that in).
Kevin
01-19-2009, 05:09 PM
thanks!!
i think lee holman still makes a cast one you can use with a water pump. check his web page.
01-19-2009, 07:56 PM
OK
Hey, funfer2/Kevin......I've got a stock one, just looking for something vintage, but thanks!!
and FWB, thanks for the info on Lee Holman, I'll check it out.
to all, thanks for the info!! I appreciate it!!
Wideglidejoe
Painted Nov 2015
