Old 04-03-2009, 12:07 PM
RedCSX1's Avatar
Default switch from small block to FE in a Superformance
My friend Richard has a Superformance and wants to make the switch from a 351 small block to a FE 428 Big Block.
The motor will be stroked. He still needs to build it.
He wants to know what parts are needed to make the swap. Currently the transmission is a 5 speed. Not sure if it’s a TKO with internal hyd. throwout bearing.
Header… where do you purchase them?
Motor mounts?
Bell housing, flywheel, clutch and pressure plate.
Starter?
Morgan LeBlanc
Fresno CA
Old 04-03-2009, 12:20 PM
CobraEd's Avatar
Stiffer front springs
________
________
Old 04-03-2009, 12:40 PM
craigayl's Avatar
Cobra Make, Engine: Superformance Cobra SC, 514CID
Polyurethane FE motor mounts
http://craigscobras.com/parts/mounts/
Polyurethane transmission mount
http://performanceunlimited.com/cobr...ransmount.html
Craig
Old 04-03-2009, 12:51 PM
Great Asp's Avatar
Cobra Make, Engine: SPO 2715
Bigger underwear (If he wears them)
E
Headers
I think a new surge tank
Old 04-03-2009, 01:29 PM
sparks's Avatar
He will definitly need some exhaust pipes from Ron at FireFly perf. Dont forget to ask about the BUNG.
Old 04-03-2009, 02:02 PM
He will of course need an FE to TKO bellhousing. If he wants to use the transmission as is, then he will need to use a bellhousing spacer or use a Quicktime bellhousing. The Tremec has a Toploader mounting pattern, but the input shaft is longer.
Depending on what clutch setup he has, he can reuse the components if they're in good condition. I sell FE flywheels with an 11" pattern, so if his clutch is an 11" Long pattern, he can reuse it.
If he has a hydraulic throw out bearing, he can reuse it as well. If the bearing is fork actuated, then he will need a longer clutch fork for the wider FE bellhousing.
I sell all of the above parts and will provide any info/support that he needs throughout the swap process.
