Old 04-14-2009, 03:23 AM
Default Spark Plug Gap
Hello all,
Question regarding spark plug gap. The motor is a side oiler 473 stroker built by Garrett Machine, runnnig an MSD ignition system. I just purchased the car (1,365 miles) and want to service the motor. The plugs are Motorcraft AGSP 32C's. What should the gap be on these plugs? I know with a hot ignition system you can run a wider gap. I haven't measured the gap on the old plugs, but they look overly wide. Any information would be greatly appreciated.
Regards,
Anthony
Old 04-14-2009, 03:44 AM
undy's Avatar
.035" to .040"
Too many toys?? never!
Old 04-14-2009, 04:16 AM
Gaz64's Avatar
Yes, you can run a wider gap, but higher compression doesn't need big gaps.
Big gaps are for stock lean burn engines so they don't misfire up to 5000 or so.
.035 -.040 is a good rule of thumb for a street engine.
The spark will jump at the shortest path to ground, wider gaps encourages crossfire, lead leakage, ignition coil failure etc.
Have a look at some racing engines, they run as small as .018.
Gary
Old 04-14-2009, 04:19 AM
Cobra Make, Engine: era 427cobra stroked 427fe
Neutral
I use autolite 3924 and gap is set at .043". With an MSD ignition you can really open up the gap.Been working great for years.
Old 04-14-2009, 05:30 AM
Thanks to all for the information regarding spark plug gap. God Bless America!
Regards,
Anthony
Rate This Thread:
