Old 08-24-2009, 04:48 PM
Default A hammer will fit this!
After working out a lot of small problems it was time to put the engine hood on and after having the expansion tank lowered as much as possible it STILL HITS THE HOOD! Maybe I should take a hammer to the corner......any suggestions....were all the tanks the same or was there ever a smaller one?
Jon
Old 08-24-2009, 05:15 PM
Is it the cap that hits? Anyway, I think you can shorten the tube that extends from the bottom of the tank to the thermostat flange.
Old 08-24-2009, 05:20 PM
Default tank
the tank has been lowered as far as it can go.
Old 08-24-2009, 05:28 PM
and backed up too I presume.....strange.
Got the correct rear tranny mount installed? Maybe a higher one?
Front motor mounts? Can anything be done there? Thinner mounts?
Wish I could help more......sorry. A call to your kit manufacturer might be next
Old 08-24-2009, 05:33 PM
Default mounts
I would like to find a pair of thinner mounts....know of any?
Old 08-24-2009, 05:34 PM
There are indeed different size (meaning height) expansion tanks. ERA won't sell you one, but there's a pic and description of their specially lowered unit on this page: http://erareplicas.com/parts/cooling.htm
Old 08-24-2009, 05:41 PM
Default tank
I had the neck cut down and it is as low as possible. the thought of a thinner motor mount to drop the motor maybe 1/2" would be great...but the bottom of my bell housing is 3.5" off the ground. I could trim it like ERA does!
Jon
Old 08-24-2009, 05:45 PM
Jon
Funny you should mention motor mounts, I was tightening mine up yesterday. ERA uses the two bolt mounts from the 1964 Galaxie. They will fit both early two bolt blocks, and the 1965 and later four bolt blocks. I don't know about "thinner" mounts.
Old 08-24-2009, 05:48 PM
Default mounts
I'm using a 3 bolt mount, i believe it is from a 69 full size ford
Old 08-24-2009, 05:53 PM
Here's my two bolt motor mount. I don't know whether it sits lower than the three bolt motor mount used in the 1965 and on cars.
Old 08-24-2009, 05:59 PM
Default mount
thanks, but different system
Old 08-24-2009, 06:04 PM
How much more room do you need to clear your hood?
Old 08-24-2009, 06:17 PM
Default clearence
i could use another .5" I thought about raising the trans but that would change the angle of the drive shaft
Old 08-24-2009, 06:22 PM
Well, I hate to tell you to beat on it with a hammer... but that's probably what I would do.
Old 08-24-2009, 06:27 PM
Default lol
LOL.....thanks
Jon
Old 08-24-2009, 06:30 PM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Okay, do you have to have the tank?
I mean is there another way to handle this without the tank?
I would love to have a 14 inch x 4 inch air cleaner, but it does not fit, so I do not have one ( this is where Pat shows us a picture of his ).
Is the engine back as far as it will go?
Old 08-24-2009, 06:47 PM
Default engine
to move the motor back is more difficult then having a radiator shop separate the two half's and remove .05" out of the height of the tank. I could also remove the tank and use a inline tube with a filler neck and a over flow tank.
I liked the tank and have built the car according to the manual...It would be nice if things would start to fit correctly.
Jon
Old 08-24-2009, 07:18 PM
toss the tank you dont need it there tanks on the sides of the radiator already,use an inline radiator cap and hook it to an overflow bottle.
Old 08-24-2009, 07:25 PM
Default tank
my upper hose is on the drivers side.....where do you find a neck that goes to the left?
Old 08-24-2009, 07:30 PM
This neck goes to the left. Seriously, have a radiator shop split it and shorten it down.
