Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Finish Line--- Speak with Paula & Enzo
Old 07-18-2005, 10:38 PM
boxhead's Avatar
Default Aero screen
Do you guys supply and sell an aero screen for a right hand drive car?
Cruising in 5th
Old 07-31-2005, 01:53 AM
BMK's Avatar
BMK BMK is offline
boxhead
Sorry to chime in here on the FL site, but have you considered drawing one onto the body and then getting the local metal shop to make one up.
The frame/ring screws down into the body in four locations using button heads and nylocks. Use about six nylocks to attach the perspex screen to the frame/ring.
Take the perspex off the ring and you can put your normal screen back on. If you want to run one..
Perhaps talk with Aussie Mike if you have no luck here.
Bernie Knight
Old 02-21-2006, 10:21 PM
Ant Ant is offline
Default Aeros screen
I am a bit interested in an Aero screen, I had one on my last Cobra, and all that it consisted of was a shaped screen with a flange bent around the bottom and fastened to the body, had about 10-12 screws!
Having said that I didnt make it, but Polycarbonate is very strong, we used it at work on our take-out shields. I reckon one only needs about 4 screws with 2 concealed under the standard screen rubber when changing back to standard!
A J. Newton
The 1960's rocked!
