Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 01-18-2011, 10:59 AM
Cobra Make, Engine: Midstates in-work again
Question High RPM's at Start
I have a Ford 5.0 EFI, three pulley system with only the sensors needed to have a motor run correctly, O2’s, ACT, Temp. I want to eliminate the high RPM / rev when the motor is first started then settles down to 900. Is there a way to adjust the EFI system so the car acts like an old muscle car / crab car?
Jeff
Treblig
Old 01-21-2011, 09:16 PM
Gaz64's Avatar
A reflash of the ECU by a competent tuner will address this.
The IAC steps during and after cranking control the engine speed.
It's a balancing act between enough air for the engine to start and then run successfully after start.
Unless you don't mind it stalling "like a muscle car".
Gary
Old 01-22-2011, 09:26 AM
Thanks for the info. I had it dyno tuned and ask the guy to retune the EEC. However when I got it home and started it up the next day, the motor races to 2500 to 3000 rpm. I guess I will have to seek out another tuner. So it is possible to fix. Thanks for the reply
Treblig
Old 01-22-2011, 11:07 AM
fordracing65's Avatar
when cold the start rpm should jump high, when it gets warm you will notice it will not jump at all when starting, that high rpm start is what i love about your set-up, it sounds very race, (there is no choke so it will jump)
Old 01-22-2011, 06:04 PM
Gaz64's Avatar
I'd agree. Who wants an engine to race to 3000 rpm cold, unnecessary, and completely fixable.
Gary
Old 01-23-2011, 08:14 PM
On a cold start, not having oil pressure at the time the engine turns over just does not sit right with me. I would rather turn down the rpm and play with the throttle. I know you can buy a pre-pressurized system that delivers oil before you start the car but I don’t know if I am going to keep this motor. Thank you for the reply. Always good to hear from people base on their knowledge and past experiences.
Treblig
