Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
Old 02-21-2013, 04:27 AM
Cobra Make, Engine: #6101 streetbeast Ingelese stack EFI 351w/t-5 9" 4link 3.55
Default efi loop
How do you loop the fuel rails on an Ingelse 8 stack efi on a 351 w. The distributer is in the way to loop in the front and if I loop it in the back it seems like the fule will go to the regulator rather than fill the other rail.
Thank you in advance...
Old 02-21-2013, 08:17 AM
bobcowan's Avatar
The trick is to make the loop wide enough so you don't put any strain on the inner lining.
Later on, I wanted individual lines for both rails. I used a Y block in the back, and then used 180* fittings in the front.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 02-21-2013, 01:34 PM
With my system I can't loop in the front.
Old 02-21-2013, 02:15 PM
bobcowan's Avatar
Why not? I was looking at the pictures on the Inglese site, and they don't seem to be much different than mine.
Input in the rear of one fuel rail, cross over/loop in the front, and the back of the other fuel rail feeds to the pressure regulator.
.boB "Iron Man"
Old 02-21-2013, 02:30 PM
My distributer is right in front of the fuel rails. Your rails look like they are about 1.5 to 2 inches higher than mine. I even bought a serious 32 small dia dist. Try to get pic for you monday.
Old 02-21-2013, 03:24 PM
bobcowan's Avatar
Yes, now I understand. If you're throttle bodies are sitting right down on the manifold, I can see where that's a problem. If you have a side mounted throtle cable linkage, you could also have some intereferance with the valve cover.
During initial assembly I had the same problems. My TB's sit on top of aluminum 1.5" spacers.
.boB "Iron Man"
Old 02-21-2013, 03:32 PM
Well Monday I am going to have my first start up. Inglese said the way I have it plumbed it should work. We will see and I will let you know. Thanks for your time.
