Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
Old 12-03-2016, 08:16 AM
Default Roush 427 IR need new idle control valve part no?
I have installed the Roush 427 IR on my Shelby Coupe.
Now i like to change the ide control valve.
Do you now what part it is? From Mustang?
Thanks Axel
Old 12-03-2016, 08:52 AM
If my memory is correct the Roush units are made by Borla.
The IAC PN is 205038
http://www.roushperformance.com/engi...structions.pdf
http://www.borlainduction.com/media/...duction_V8.pdf
Old 12-04-2016, 04:29 AM
Here pics of my engine, the air control value i need is under the 2 fuel rails
Old 12-04-2016, 06:50 AM
I can't see it but that location is next to the throttle bellcrank. They may be using a simple solenoid to step up the idle for A/C and power steering loads.
Best to give Roush a call. They are East Coast based. You are +6 on time zone to them.
1-800-59-ROUSH
Old 12-04-2016, 09:10 AM
Forgot "800" numbers don't work from overseas.
These should help.
https://www.roush.com/contact-us/
Old 12-06-2016, 06:50 PM
PANAVIA's Avatar
IACs are stepper motors -not solenoids.
-- you need to know what Vintage of 427IR this is, as Roush has changed suppliers many times over the years.
Be prepared with your #SN and call mark yagelo -
Old 12-07-2016, 07:28 AM
Brilliant observation, and that's why I used a different nomenclature when referring to a different type part.
Contact info for Mark Yagelo: 734-779-7243 mark.yagelo@roush.com.
Old 06-01-2017, 05:40 PM
Cobra Make, Engine: 1992 Classic Roadsters, 427 Dart Stroker, Tremec 5spd, 8.8 positrac differential
Default Iac
Not sure how your IAC is set up on the intake, but I just did an install on an 8 stack system and used a remote IAC valve that I mounted to the firewall. It was just a simple matter of running the vac line and the wiring to the remote IAC. This particular IAC stepper motor is the same that is used on a
Chevrolet LS-1 Engine so they are commonly available. I purchased my Remote IAC on E bay. Just a thought but from looking at that rousg set up it would be a pain pulling all the fuel rails just to change the IAC. Good luck
