Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
Like Tree2Likes
  #21 (permalink)
Old 05-29-2021, 06:32 AM
undy's Avatar
Because of the cost and bad health I've decided to just disassemble my current 428FE and stroke it out.
Which company's kit would you recommend or to buy individual parts ?
Is it lower cost to buy a kit ?
My Dove engine is .030 over, would you suggest staying with it or higher ?
What kind of power could it be ?
Kev, given your situation I think you made the best choice. I'd talk to Barry @ Survival Motorsports or Blykins about a rotating assembly. Given your heads (not the best) I'd think somewhere between 500 and 550 hp would be reasonable. Go with an Hydraulic Roller cam, not a solid roller or any flat tappet. You'll appreciate the HP and reduced maintenance. If you were trying to extract every drop of power AND had a very light rotating assembly (high $$) then a solid roller would be the best power ticket.
Too many toys?? never!
  #22 (permalink)
Old 05-29-2021, 09:24 AM
eschaider's Avatar
Kevin,
A 0.030 over block does not leave much room for another overbore. More significantly, the additional overbore doesn't give you much more displacement or power.
If you are looking for additional low speed torque and power to raise the car's fun factor you ought to consider the bigger bore 427 block (still with a stroker). Talk to Brent (blykins) about what you want from the engine and let him build one for you. That is really the short way home in terms of money you spend and results you get.
cycleguy55 likes this.
  #23 (permalink)
Old 05-29-2021, 10:42 AM
FUNFER2's Avatar
Check out this 428 stroker.
Cubic Inches: 465 Peak Horsepower: 629 HP @ 5900 RPM Peak Torque: 616 @ 4700 RPM
Engine Specifications:
Block brand: Ford C-scratch CJ 428, .050" over
Crankshaft brand: SCAT cast 4.25 stroke
Connecting Rods: 6.7"
Pistons: CP
Oil Pump: Melling, corrected by Greeley Automotive Machine
Oil Pan: Moroso 7 Quart w/ windage tray
Cam: Bullet hydraulic roller cam, slightly under .600" lift measured at valve, 110 lobe centers
Lifters: Crower HIPPO solid rollers
Cylinder Heads: C4AE-G, CNC ported with matching port job to Blair's EMC entry
Rocker Arms: T&D single shaft
Intake manifold: Performer RPM
Carb: Blairs EMC dyno carb
BP 428CJ Stroker - 465 Cubes
Regards,
Kevin
  #24 (permalink)
Old 05-29-2021, 08:19 PM
cycleguy55's Avatar
Check out Brent's website. He doesn't show as many different engines (including dyno results) as he used to, but he can no doubt build you a great engine.
BTW, check out his FE rocker arms, good for building a 7,500 RPM hydraulic roller FE.
https://lykinsmotorsports.com/
Lots on Brent's YouTube channel: https://www.youtube.com/channel/UCvO...ohy4Q/featured
449 FE Road Race Engine, 664 HP, 614 TQ https://www.youtube.com/watch?v=mQ3tRJdDwFQ
445 FE, 536 hp, 575 lb ft. https://www.youtube.com/watch?v=CaBFgzQSi6w
Brian
  #25 (permalink)
Old 05-30-2021, 04:38 AM
undy's Avatar
Pistons: CP
I'd be scared as hell with an 0.050" overbore. The ONLY way I'd touch or even consider a block like this would be with a very detailed sonic bore test.
  #26 (permalink)
Old 05-30-2021, 05:22 AM
FUNFER2's Avatar
Do you know the stats on this engine ?
Regards,
Kevin
  #27 (permalink)
Old 05-31-2021, 02:39 PM
cycleguy55's Avatar
No, but Brent Lykins (CC member name 'blykins') will know them intimately. He may weigh in on this thread, but I wouldn't hesitate to give him a call if I was in your shoes.
P: (502) 759-1431
E: brent@lykinsmotorsports.com
Brian
  #28 (permalink)
Old 05-31-2021, 07:44 PM
FUNFER2's Avatar
I will, thank you.
Regards,
Kevin
