Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
  #21 (permalink)
Old 02-11-2008, 04:35 PM
Cobra Make, Engine: SPF 2293, Roush 427R-228
damn if I had the cash I'd be in for 351w buy. With stocks sucking, real estate sucking, oh and twin boys due in a few weeks I'm definetly out. Ask me again next year
  #22 (permalink)
Old 02-12-2008, 07:14 AM
thorconstr's Avatar
Cobra Make, Engine: ERA 427" 351W
Smile
dlang, I understand fully, that is the reason I am doing this. After the election everything will turn around, it usually does, they do manipulate us. Thanks for the interest, Al
Al W.
  #23 (permalink)
Old 02-15-2008, 07:48 PM
Hey this looks good I might be in for a 351 kit any orders yet?
Originally Posted by thorconstr View Post
JTD, That is correct, approximately $685.00 less than the already discounted price on my web site. Thor Motorsports - TWM Induction Authorized Dealer - Competition/Street Fuel Injection Systems and Accessories for a complete setup for you plus 4 more people as a group. It's a great deal!
  #24 (permalink)
Old 02-16-2008, 09:27 AM
thorconstr's Avatar
Thumbs up buyers
Rick, One guy right now!
Al W.
  #25 (permalink)
Old 02-21-2008, 09:49 PM
I might be interested too.
I'm just talking to engine builders right now and I want a stack system.
Mike
(my post count is so low as I'm usually on ffcobra.com)
  #26 (permalink)
Old 02-22-2008, 06:22 AM
FUNFER2's Avatar
Al, can you give me a apx.,... total cost for a FE ?
Injectors
F.A.S.T system
Pumps ect.
Ready to run.
Thanks
Regards,
Kevin
  #27 (permalink)
Old 02-22-2008, 07:49 AM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Cobra Make, Engine: Street Beasts w/302 Twin Turbocharged....Under Construction!!
Send a message via AIM to EarlsflyinCobra
What all is included in this kit????
TWM Induction Kit: Ford 289/302/351
List $3,995.00 YOUR PRICE: $3,395.00
Safe Flyin, errrrr Drivin, Earl
  #28 (permalink)
Old 02-22-2008, 08:57 AM
thorconstr's Avatar
Thumbs up TWM pricing for Ford small block
Earl, A group purchase would result in a $697.50 savings from pricing below!
Thor Motorsports
Competition Fuel Injection
Systems and accessories
Al Wohlstrom
7890 East Starbright Court
Tucson, Az 85750
Cell 520-401-9142
thormotorsports1@msn.com
www.thormotorsports1.com
Re: TWM injection for 351W Ford
351W Ford application includes four 50mm two barrel throttle bodies, manifold, manifold mounted linkage, vacuum plenum, fuel rails, TPS, and air horns. Retail $3,995.00 your price $3,395.00
F.A.S.T. XFI ECU, wiring harness and O2 sensor 2,190.00
F.A.S.T. injectors 42 lb/hr 650.00
MAP, water, and air sensors 110.00
Aeromotive fuel pump, and filter 450.00
Throttle cable 105.00
Shipping 75.00
Total $6,975.00
Optional nostalgia air horns with screen filters $400.00
Optional IAC (idle air control) $249.00
Optional screen with foam filters for standard air horns $187.00
Optional polishing of manifold, throttle bodies, plenum, linkage, air horns & fuel rails $1,650.00 About 3 to 5 weeks backlog.
Optional air cleaners K&N filters are $400.00
I require 50% deposit to place the order an 50% when the order ships. I take Master Card & Visa. Thanks, Al
Al W.
  #29 (permalink)
Old 02-22-2008, 09:16 AM
thorconstr's Avatar
Thumbs up TWM pricing for Ford FE
Kevin, A group purchase would represent a $765.00 savings from the pricing below.
Thor Motorsports
Al Wohlstrom
Tucson, Az 85750
Cell 520-401-9142
email thormotorsports1@msn.com
Re: TWM injection for 427 FE Ford
427 FE Ford application includes four 58mm two barrel throttle bodies, manifold, manifold mounted linkage, vacuum plenum, fuel rails, tps, regulator, and air horns. Retail $4,785.00 Your price $4,065.00
F.A.S.T. XFI ECU, wiring harness and O2sensor 2,190.00 F.A.S.T. injectors 42 lb/hr 655.00
Shipping 75.00
Total $7,650.00
Optional Nostalgia air horns with screen/foam filters $400.00
Optional screen with foam air filters for standard air horns $187.00
We require 50% deposit to place the order an 50% when the order ships. I take Master Card & Visa. Thanks, Al
Al W.
  #30 (permalink)
Old 02-22-2008, 09:35 AM
thorconstr's Avatar
Thumbs up Ecu
I also have a new ECU that can be used with either one of these setups without all of extra bells and whistles (NOS ect.) for $1,625.00. Very user friendly and great for street use.
Al W.
  #31 (permalink)
Old 02-22-2008, 09:44 AM
Ouch Ouch Hot Sand
Al,
I already have 42lb. injectors, an aeromotive in tank pump and filter, and a Micro Tech ECU. I am running Twin Garrett Turbos on a 5.0 with E303 cam and Y303 heads. SO, would I need to ditch this stuff or could your system, less the parts above, be used??
Thanks, Earl
  #32 (permalink)
Old 02-22-2008, 10:45 AM
thorconstr's Avatar
Earl, I believe that the ECU would work, (you may want to talk to Microtech about that) and I would need a part # for your injectors. I take it that you have a return line already? If the ECU, injectors and pump/filter work, then all you would need is the TWM and whatever sensors you dont have.
Al W.
  #33 (permalink)
Old 02-22-2008, 10:46 AM
RodKnock's Avatar
Al, how much longer will you be running this special?
  #34 (permalink)
Old 02-22-2008, 11:01 AM
thorconstr's Avatar
I need to have 5 or more orders filled by March 15, 2008
Al W.
  #35 (permalink)
Old 02-22-2008, 04:20 PM
Calbullet's Avatar
Cobra Make, Engine: Superformance 460 SVO
Al, I have a Superformance with 460. does your system have provisions for power brake booster and PCV valve. also what would a ball park price be for a complete system.
Mel
  #36 (permalink)
Old 02-25-2008, 07:30 AM
thorconstr's Avatar
Thumbs up TWM 460 Ford pricing
Mel, A group purchase would result in a $825.50 savings from pricing below!
Thor Motorsports
Al Wohlstrom
Tucson, Az 85750
Cell 520-401-9142
Re: TWM injection for 460 Ford
460 Ford application includes four 58mm two barrel throttle bodies, manifold, manifold mounted linkage and vacuum plenum, fuel rails, TPS, regulator, and air horns. Retail $5,500.00 Your price $4,675.00
F.A.S.T. injectors (size determined by application) 650.00
Aeromotive fuel pump and filter 450.00
Shipping 75.00
Total $8,255.00
Optional screen/foam air filters for standard air horns $187.00
Optional nostalgia air horns and mesh and foam filters $400.00
Optional polishing of manifold, throttle bodies, plenum, linkage, air horns, and fuel rails. $1,650.00
We require 50% deposit to place an order, and 50% when the order ships. We take Master Card, and Visa. Thanks, Al
Al W.
  #37 (permalink)
Old 02-25-2008, 08:25 AM
thorconstr's Avatar
Default Brake booster
Mel, The brake booster vacuum pickup is shown below. I'm checking into the pcv.
Al W.
  #38 (permalink)
Old 02-25-2008, 08:32 AM
thorconstr's Avatar
I don't have a clue what happened to the attachment, click this link. TWM Induction - V8 Kits
Al W.
  #39 (permalink)
Old 02-27-2008, 12:12 PM
thorconstr's Avatar
Exclamation Deadline for group purchase
I need to have 5 orders for complete setups ( TWM induction, injectors, fuel pump, filter, ECU, etc.) in by March 15, 2008 to take advantage of the 10% overall discount. I don't believe this will be offered again this year.
Al W.
  #40 (permalink)
Old 02-27-2008, 01:16 PM
RodKnock's Avatar
Al, thank you for the reminder.
I was meaning to ask an FE-related question. Is there a picture comparison of standard versus nostagia air horns? I'm trying to figure out what the appearance of the standard air horms, which I believe comes with the $7,000 ($7,650 less $765) package versus adding another $400 for the nostalgia air horns. Also, if a buyer went with the nostalgia air horns, is there a 10% price break on the option(s)? Thank you.
Display Modes
