Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
  #21 (permalink)
Old 08-29-2008, 08:37 PM
I got the impression from talking to MassFlow that my EEC is still bone stock the way Ford made it. The newer stuff MassFlow sells is chipped and they put a tune in it based on your engine. They will redo mine that way for about $250 or so, if I send them my MAF, and EEC. I'm sure it would improve things, but I just don't see it doing as well as actually measuring the exhaust on the actual running engine.
  #22 (permalink)
Old 08-29-2008, 08:47 PM
ByronRACE's Avatar
Cobra Make, Engine: West Coast Cobra w/ Centrifugally Blown Big Block, Pickles, Onions, on a Sesame Seed Bun.
Default You're right
You're right, there's nothing better than doing your AFR tuning on the engine in question.
However, the difference between what you are running now (a calibration designed for a 5.0L Mustang with a 137 firing sequence, 301.08 cubic inch displacement, 19lb/hr injectors, smog legality, etc...etc...) and the *right* calibration for the parts that the EFI system is actually connected to is going to be night and day....even before performing the fuel trim operation on the engine in question. You can do this baseline tuning stuff yourself with the tweecer, then you'd have the ability to take it further if you so chose. If you have massflow do the baseline stuff, that's probably where it ends because you don't have their tuning software/system. The only thing stopping you from doing the baseline calibration stuff yourself is knowledge of the massflow curve in Volts vs KG/Hr. If they'll give you that, you're home free and you could have this put together in an afternoon.
BTW, I ran a google image search and ran into this...which looks familiar I hope. There's an applications list on the page that suggests this is a GM type maf...so whatever you have is probably a GM type maf. Probably not this one though; I'd suspect they'd use something from a performance vehicle so it has enough measurement range (Corvette, Camaro). Again, just a guess.
http://www.cheaptruckparts.com/produ...ucts_id/27187/
http://www.corvetteguys.com/mass-air-flow-sensors.html
  #23 (permalink)
Old 08-29-2008, 08:55 PM
ByronRACE's Avatar
Default Firing sequence
What is the firing sequence on the engine you're running. If it's 154, I have some input why you're having problems.
  #24 (permalink)
Old 08-29-2008, 08:58 PM
Originally Posted by ByronRACE View Post
ps, the external chip/tweecer like devices disable the onboard chip (there is a control line on the port for this purpose) and substitute off-board memory (their own chip that is interfaced to look like Fords original). The process is temporary....remove the external chip from the socket and the control line is no longer activated and the internal memory is enabled.
I just caught this. Ok now it all makes sense. Everything would have to be set up from scratch and none of fords programming would be used. The Tweecer programming would be used, and I would have to fill in all the data.
Does the Tweecer and/or the software come with good instructions?
I am a process control guy buy trade and have programmed lots of processes with PLCs and other control systems. However I hate unfriendly software, and I want to understand the complete picture before I program anything. One of my faults, is obsesive perfectionist. I hate to monkey with it until it works. I want to understand both theory and real world, when I work on something. I like a scientific approach. I hate following someone who tinkered intil it worked, but had know idea or incorrect assumtions as to why it worked. **** like this always comes back to bite you when anything changes. I'm not intimidated by tuning it myself, but I'm still way too in the dark for my comfort.
  #25 (permalink)
Old 08-29-2008, 09:03 PM
No. Mine is the 137.... So I think my cam is the correct firing order for a stock 5.0 EEC.
  #26 (permalink)
Old 08-29-2008, 09:06 PM
ByronRACE's Avatar
Default Hehe
Well from one anal retentive nerd to another, you'll never be happy with how the engine runs unless you do it yourself, so I'd recommend diving into this with both feet.
TwEECers software works fine. Is it perfect, no. Is it wonderfully documented, no. Does it work, yes. Is it free of major bugs, yes. Diablo and SCT have offerings too; both of which are better documented, more complete, and more costly. The functionality they uncover can be useful, but to be completely honest Tweecer exposes everything you need to make the car run great. Let's put it this way, I'm using really ancient Autologic software that predates Tweecer, and even that exposes enough functionality for me to be happy with all my EEC-IV vehicles.
If you want to get a feeling for what kind of parameters are available and what the software looks like you can download it in advance. You can also download paul booths software, which www.moates.net devices works with. You could do this with the moates stuff too; it's just slower because it's not USB and flashable in-car, as far as I know. Anyway, I'd look at the software before you buy...and keep in mind, you will be starting with the Ford template and Ford parameters...so change nothing and it runs like it does now. You will start small...change engine displacement to actual, raise idle rpm 300 rpm to make sure it works...try it...repeat...
  #27 (permalink)
Old 08-29-2008, 09:08 PM
I'm starting to turn pink. It's past my bed time so I'm going to go to bed before I finish turning into a pumpkin. Catch you later.
PS that sounded rude. I didn't mean it to. I have a car show tomorrow and a full week end of out of state relatives. I cannot wait to dig into some of the links you gave. Then I will have even more questions. It may take a few days to get back to this.
Thanks
  #28 (permalink)
Old 08-29-2008, 09:22 PM
ByronRACE's Avatar
Default MAF curve thought.
If the guys at Massflow are running a stock PCM, then we already know what the resulting MAF curve being fed to the PCM is.
It's the factory ford 19lb/hr curve scaled to whatever the change in injector size is...exactly the same thing they do on 5.0L mustangs. The only detail in this case is that this "scaling trick" is being done in a frequency to voltage converter box. In a Ford MAF they calibrate the analog electronics to scale the voltage. The massflow guys do something else. They probably use a microcontroller, calculate the frequency of the GM MAF output, then use an internal lookup table to look up what the output voltage should be, and produce it using a digital to analog converter. This allows them to put anything they want in the lookup table and translate any GM input curve to any Ford analog output curve; and scale it for any size injector. That's a lot of work, but it lets them use off the shelf stuff that's easier to cram into an air filter than the Ford design. This lookup table would also allow them to avoid hitting the .4V minimum voltage that flags a check engine light when you use the "scaling trick" on big injector engines. Once you get beyond about double the factory injector size, you start hitting that .4V in the idle range and the PCM goes into limp mode. They probably flatline the output above .4V to avoid this...so they can make 40+lb/hr injector calibrations run on factory PCMs.
Anyway, if you're running a factory Ford pcm (look at the prom like I suggested for signs of tampering), we know what curve is being fed to the PCM. One less thing you have to ask for.
Byron
  #29 (permalink)
Old 08-30-2008, 03:56 AM
Mac VABCH's Avatar
Cobra Make, Engine: BDR #250
Olddog,
Byron is correct that you have a factor unchipped PCM. MassFlo initially sold there system in stock form now he uses a piggy back chip to tune for displacement and injector size. I have not been able to tune the PCM to the new meter after massflo sent me the flow sheet as I have been out of the country for 3 months. I will say that when I first received the new meter withot a flow sheet we couldn't get the tune right as it was very rich. When I sent the meter to Chris at MasFlo he said that there must have been oil contamination to the mete/intake which he suggested was from to much oil on the filter. This was not the case as the filter hadn't been reoiled in a quite awhile. Where the oil contamination came from was the PCV. I have since deleted the PCV and just put a filter on the valve cover. I will be returning to the states next month and will get the tune right then. I still think that your injectors are 1 size to big as I have had the motor running great and only making 340 WHP. This was with a 12yr friend that does this for a living tuning it over and over again to get the most out of the engine. I don't put to much faith in pc dyno numbers. JMHO. I'm not sure if I gave you the email or not to my tuner but he uses Diablo chip and has a tune for my car on file when it ran great. brenth@dtpracing.com
He can give you his opinion as to which way to go either a Tweeker or Diablo or have MassFlo do it. I will say that if you go with MassFlo it will be a guess, if you go with Tweeker you will have to learn how to tune it and spend expensive time on the dyno or data log on the street. Brent should still have a good tune that will be very close for you setup as we have very similar engine but not perfect. Mac
  #30 (permalink)
Old 08-30-2008, 08:47 AM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Olddog:
You may very well have a chip in the J3 port of the A9L supplied by Mass-Flo to adjust for whatever combinations are in the engine.
According to Tweecer, if you order the Tweecer unit and send them the J3 chip they can read it for you and create a .bin file to load into the Tweecer before you start. That way the Tweecer is providing the same information to the A9L as the J3 chip installed now. From that point you have a functioning unit and can tune from there.
For a small fee they can also read and create the .bin file from the chip without purchasing the Tweecer.
I have a Mass-Flo on my 428FE and, while the system is running well I'd still like to refine it just a bit. I'm thinking seriously of going the Tweecer R/T route this winter when the car is up for it's annual maintenance/modification/cleaning all the accumulated gluck off of it session. Like you I'm a relative novice to the EFI tuning world so it should have some "interesting" periods.
DonC
  #31 (permalink)
Old 09-11-2008, 06:11 PM
Ok I down loaded the .pdf file for the Tweecer manual and read it a couple times. It leads me to believe that you can down load all the tables from an EEC IV, but stopped short of stating that you can transfer this file into the Tweecer as one of the 4 selectable tunes, allowing you to start with a tune identical to the factory settings. If you can do that, you could start identical to where you are at. Is this doable?
I'm thinking the first thing I should do, is correct all the modification that were done to my engine. Put in the right CID, the enjector size, and mass flow meter size.
From my understanding they likely set my MAF up with a range larger than my engine needs. Since the factory used 19 lb/hr and I have 36 lb/hr injectors and I'm guessing the factory used about a 650 cfm meter, the math comes out to 36/19 * 650 = 1230 cfm. I think I was either told by MassFlow or read it in the literature that it is 1200 cfm. That is likely too big for 347 cid. I'd think 700 cfm would be enough. Is only using a little over 1/2 the range of my MAF going to hurt the resolution enough to matter?
  #32 (permalink)
Old 09-11-2008, 06:28 PM
To get the O2 sensors close enough to the engine, they had to be located into a single header tube. The collector is 1/3 the way down the pipes that you can see on the car. Also my pipes are jet hot coated. I don't like the idea of welding bungs into my side pipes. Is there a way to just slide the wide band O2 sensor up the side pipe from the outlet?
Also I have read some comments that some wide band O2 update rate is so slow compared to how fast the rpm comes up that it gives you numbers but you don't actually know what the rpms were, making it hard to correct your tables. Is wide band O2 the best technology to use? Are some O2 much better than others?
  #33 (permalink)
Old 09-11-2008, 07:17 PM
For anyone else interested in the tweecer here are a couple video links.
http://v8tvshow.com/content/view/216/28/
http://v8tvshow.com/content/view/217/28/
