Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
Old 09-08-2008, 06:41 AM
Cobra Make, Engine: ERA #773, 482 stroker, cross ram stack injection
Default Idle Air Control Location
Where do you locate the idle air control air source on a stack injection intake manifold? Is one source adequate, or do you have to source all eight runner tubes?
Old 09-08-2008, 07:43 AM
thorconstr's Avatar
Cobra Make, Engine: ERA 427" 351W
Here's where we mount our IAC, the source is the plenum.
http://www.clubcobra.com/forums/atta...2&d=1203702984
thormotorsports1@msn.com
www.thormotorsports1.com
Al W.
Old 09-08-2008, 08:52 AM
fkemmerer's Avatar
Cobra Make, Engine: ERA, FE BBF
What is typically done is to install plumbing under the intake. In this setup, a hardline is run from each point to a common reservoir under where the breather would go at the back of the intake. The IAC motor then attacheds to the common reservoir via the breather hole. Here's a picture of how this looks on my TWM intake.
Here's a picture of the hardline connections in the ports:
Here's a picture of the common reservoir at the back of the intake:
And here's a picture of the IAC motor mounted on top of the intake:
Hope that this helps.
