Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
Old 09-24-2008, 08:17 PM
shark's Avatar
Cobra Make, Engine: Superformance Brock Coupe
Default TWM TPS Sensor
Gentlemen - does anybody have the part number/make for the throttle position sensor used on the twm induction. Looking to run down to the local store and get a replacement. My 1st FI stack system and I have some faint clues as to where it's located on the side of stack -- it just unscrews and unclip harness then reset the ECU for closed and open throttle postions within one's ECU program? I'm using the Motec M-48
Thanks, Mike
Old 09-24-2008, 09:14 PM
anicholas's Avatar
Cobra Make, Engine: Kirkham FIA
Mike,
What engine do you have? There is one TPS for a small block (351) with a grey center and a different one for a big block (FE), all black.
anicholas
KMP 517
Old 09-24-2008, 09:43 PM
thorconstr's Avatar
Cobra Make, Engine: ERA 427" 351W
Default TPS part #
The part # is 2900-3040
www.thormotorsports1.com
Al W.
Old 09-25-2008, 07:25 PM
shark's Avatar
I have the grey center 351W based unit. I now TWM's part # but without first taking the unit off and seeing if it has any manufacturers ID I wanted to run down to my local parts store and get a new piece. TWM stated it's made for them ..... but I'm sure it's made for a over the counter system. Just like the Superformance cobra clutch slave cylinder is from a 1988 Izuzu p/u I'd imagine the TWM # 2900-3040 must be from something....?? anicholas & AL -- you are both correct and thank you for the input. Sharkey
