Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
Old 12-03-2008, 01:50 PM
Cobra Make, Engine: Building ERA #749 427 Cobra
Default Fuel injector installation problem
Has anyone out there had a problem getting fuel injectors into the bosses on Edelbrock FE fuel injection manifold for the FE engine? I've done a lot of injector installations and never had a problem. The fuel rail side fit and installation was easy but no matter what force I use to get bottoms into the manifold, no go. I'm using the mass-flo efi system with the black injectors. Although there is a chamfer on the manifold, it seems like the actual bore where the O'rings go in is very sharp.
Old 12-03-2008, 01:57 PM
Blittleton's Avatar
CC Member / Sponsor
Did you try some vaseline, this usually helps me out on tough ones.
Bill
www.gcperf.com
Old 12-03-2008, 02:04 PM
I used motor oil and then silicone spray. I'll give vasoline a try.
Old 12-03-2008, 05:01 PM
Thanks for the help Blittleton. It was still a struggle, but the Vaseline did work.
I measured the manifold bores and the passenger side bores were .0035 smaller than passenger side which might have made it harder too.
Old 12-09-2008, 03:19 AM
PANAVIA's Avatar
I use Dextron ATF to lube injector seals prior to insertion. (same idea)
Old 12-09-2008, 07:51 AM
lovehamr's Avatar
Stolen Avitar
Bill
Whew! For a second there I thought that was a proposition.
Steve
Old 12-09-2008, 08:17 AM
philminotti's Avatar
Hey Steve-
Loved your reply to the fella who was critical of your avatar over on the other site. Banana hammock! LOL!
phil
