Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
Old 01-10-2009, 06:08 PM
EarlsflyinCobra's Avatar
Ouch Ouch Hot Sand
Send a message via AIM to EarlsflyinCobra
Default Help with Upper Intake Manifold
I have an upper with the following code......RF-F32E-9426-CB......any help with this code would be greatly appreciated. Thanks, Earl
Old 01-10-2009, 07:13 PM
PANAVIA's Avatar
are you sure that is not F3ZE or F3SE >?
-9426 is a Ford intake number, but the prefix is typo'd i think.
Old 01-10-2009, 07:27 PM
Ouch Ouch Hot Sand
Oppppppppppsssssssssss, sorry, it is F3ZE....thanks, Earl
Old 01-10-2009, 08:13 PM
Seagull81's Avatar
Cobra Make, Engine: FFR3542K, 347 C. I., EFI, T-5, Miata Front Sway Bar, 3 Link, Red with White Stripes
It should be a Cobra intake. It should have offset intake runners. Better than the stock HO intake.
I hope these pictures come out.
Steve
Old 01-10-2009, 08:17 PM
Seagull81's Avatar
Old 01-10-2009, 08:26 PM
Ouch Ouch Hot Sand
Okay, great, now next two questions, the little pipe sticking out to the left and below the 8 intake holes in the picture, where does it go to and the T fitting thats supposed to be in the bottom left corner, where does it go??
Old 01-10-2009, 10:58 PM
PANAVIA's Avatar
so you may need things drawn from manifold vacuum.
1. Power Brake Boosters.
2. PCV valves
the middle one is used as PCV, the fitting on the corner can be used for a PBB.
if you are not using a PBB you can cap it off with a NPT plug.
I always advise the running of a PCV valve, it reduces crank case acids and keep unburned gasoline vapors from messing with things, like bearings.
--Steve
Old 01-13-2009, 01:04 PM
Ouch Ouch Hot Sand
I am not running a pbb so is there any other reason not to cap off the corner hole?? Also, the one underneath, you say it is for PCV, so the hose runs from there to the vavle in the rear of the lower intake??
Thanks, Earl
Old 01-14-2009, 01:00 AM
PANAVIA's Avatar
Go ahead and Cap it. -- yes that is correct. dont forget the screen in the lower intake under the PCV.
Steve
Old 01-18-2009, 09:00 PM
Ouch Ouch Hot Sand
Default INTAKE Mystery Hole.........LOL
OKAY, sorry for the CRUDDY picture, but its all I could get tonight.....
There is a brass pipe on the left side of the pic, which I assume is the one that goes to the PVC valve.....what is the hole on the right where a fitting screws into??
In seagulls above picture the hole is right below the pipe thats sticking out.........
Old 01-18-2009, 11:05 PM
PANAVIA's Avatar
need better picture.....
Old 01-19-2009, 06:44 PM
Ouch Ouch Hot Sand
Hopefully this is better...............
