Go Back   Club Cobra > Engine Building, Tuning, and Induction > Fuel Injection & Tuning
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-05-2009, 11:26 AM
stuartb's Avatar
Cobra Make, Engine: shell valley, 427ci 500hp
Default Anyone using mass flo?
Is anyone using mass flo fi system? My system is running rich and causing a stumbling problem. Don't know if it is the computer programing or if it is a bad sensor. Need a little input.
Old 02-05-2009, 11:51 AM
Stuart
Speak to the guys over on the www.ffcobra.com forum
Old 02-05-2009, 12:18 PM
Mac VABCH's Avatar
Cobra Make, Engine: BDR #250
Stuart,
I am using MasFlow with out any problems. I did have to get it tuned on a chassis dyno to get rid of the rick condition when I first got the car on the road. Call Mass Flo they should be able to give you some options...Mac
Old 02-05-2009, 04:30 PM
I have an older mass flow. Has your computer been chipped? Mine was not, and my fuel is not right anytime it is in open loop.
Old 02-05-2009, 05:10 PM
flyboy1997's Avatar
Send a message via Yahoo to flyboy1997
Is it a new install?
Keith Craft Plano had fits with mine until they discovered mechanic had installed distributor off timing, # 1 wire HAS to be on # 1 spot on distributor. Will run but has a Bad Stumble!
Old 02-05-2009, 07:48 PM
Larry N Johnson's Avatar
Cobra Make, Engine: FFR 3850, 95 Cobra 5.0 EFI, IRS, Pin Drive 15" real Magnesium Halibrands & Vintage Wheels, Billboards & Mickey Thompson S/T tires, Blue/Wht Stripes, Hoops, CSX Dash, Konis, VPMs, Torsen
If the mass air flow sensor and the injectors are sized to match, it should run sweet after about 5 starts and 10 minutes run each time (for EEC to "learn").
Assumptions:
1. EFI Distributor wiring as per flyboy1997 mentioned.
2. Stock Ford EEC as recommended by Chris at Mass Flo.
3. Grounds all installed.
4. Initial timing w spout out at 12-14 degrees
5. O2 sensors wired correctly.
6. Fuel pressure set at 38 PSI or as recommended for your injectors.
7. IAC installed and wired right. (Idle Air Control valve)
