Go Back   Club Cobra > Club GT40 Areas (MKI - MKII - MKIII - MKIV) > GT40 Talk
User Name
Password
Club Cobra Home Register FAQ For Sale Calendar Today's Posts Journals
Old 07-17-2010, 11:52 AM
Cobra Make & Engine: Kirkham 427
Send a message via AIM to jpfletch1 Send a message via Yahoo to jpfletch1
Default 1 1/4 inch aluminum T
My project is stopped because I can not find a 1 1/4 inch aluminum T for a water manifold connecting to my webers. Does anybody know where I could find this piece. I do not have the ability to weld aluminum or I would make it myself. Thank you jpfletch@pacbell.net
Old 07-17-2010, 12:31 PM
FWB's Avatar
FWB FWB is offline
Cobra Make & Engine: Kellison Stallion 468 FE
try here.....
http://www.mcmaster.com/#aluminum-pipe/=804xfm
Old 07-17-2010, 02:17 PM
Jerry Clayton's Avatar
Cobra Make & Engine: Everett-Morrison LS1
also look at stainless steel pieces
Old 07-17-2010, 02:55 PM
Jac Mac's Avatar
Cobra Make & Engine: DIY Coupe, F/T ,MkIV.
I see blue thunder sell this proper piece for SBF, is that what you want one for...or another application.
I was just on the Ford 'Y-Block' site & they have a pic in the SBF Weber manifold section..
Jac Mac
Old 07-17-2010, 03:10 PM
Rick Parker's Avatar
Cobra Make & Engine: NAF 289 Slabside Early Comp Car with 289 Webers and all the goodies. Cancelling the efforts of several Priuses
What engine are you working with? Is this what you are attempting to create??
[IMG][/IMG]
Old 07-17-2010, 08:13 PM
mickmate's Avatar
Cobra Make & Engine: CSX 4772 old iron FE
I can make it if you can't find it anywhere from the leads given.
mickmate
http://www.actoncustom.com/
Old 07-18-2010, 09:03 AM
[IMG][/IMG]
It is on a 302. I am going to post a photo later today. I have seen your set up before but what are the 4 tubes for ? Thanks Jim
Old 07-18-2010, 10:27 AM
This manifold design incorporates a fuel distribution block. Others just run a single line from the pump then in series to each carb. Used on 289 Cobra.
Old 07-18-2010, 01:31 PM
Jac Mac's Avatar
Smile
From what I understand this is for an ERA GT40?, & these cars per the ERA info have the coolant going from the outlet or T/Stat via this 'Tee' into the bottom of the header tank which appears to be mounted on the RHS firewall-beside #1 plug-. The 'Tee' is mounted between the water outlet & header tank & is also attached to the pipe going fwd to the radiator. Therefore the 'Cobra' type water neck will exit on the wrong side.
JP Fletch also posted this enquiry on GT40's, I was able to attach a dwg on that site, it wont upload here for some reason..
If Im correct he wants a simple single barbed 'Tee' fitting in alloy to suit a hose with 1.25" bore
Jac Mac
Old 07-18-2010, 08:34 PM
Correct, I could not have said it better myself. Thanks everyone
Old 07-19-2010, 10:07 AM
[ATTACH]Name:  gt 001.jpg
HELP Here is the fitting I need for my ERA gt40. It is a 1 1/4. Does any one have this or know where to get it. Thanks
Old 07-19-2010, 11:17 AM
Cobra Make & Engine: Size 10 Feet
Have you called ERA (since we make that here?).
