Go Back   Club Cobra > Club GT40 Areas (MKI - MKII - MKIII - MKIV) > GT40 Talk
User Name
Password
Club Cobra Home Register FAQ For Sale Calendar Today's Posts Journals
Old 07-30-2015, 02:34 PM
JerseyDanny's Avatar
Registered User
Originally Posted by JerseyDanny View Post
Glad I found this site - - good accurate info & no attitudes (MINE is bigger/thicker/harder than YOURS) that is found on OTHER forums. Am looking for a GT40 for a customer that has an aluminum FE mid-riser build here at our shop with an IR-EFI setup - stroked & bored to 481 inches. Need a GT40 that can take an FE engine. Like the look of the CAV. A stainless monocoque? Sounds good, too!
Thanks for all future info, everybody!
JerseyDanny
"Mark Donohue is right - - too much is JUST enough!"
Old 07-30-2015, 03:37 PM
Cobra Make & Engine: SPF GT40
SPF can accommodate an FE as well. SPF provides exhaust headers for that. QuickTime makes a bellhousing to mate FE and ZF (RBT) trans too. Depends if your customer is more interested in a stainless tub and non original suspension (CAV) or virtually total originality (SPF).
Old 07-30-2015, 03:58 PM
RCR40 MK1 will go FE at a squeeze but MK2 and MK1V are the FE powered cars
Old 07-30-2015, 10:51 PM
Jac Mac's Avatar
Cobra Make & Engine: DIY Coupe, F/T ,MkIV.
Don't rule out a MK1 style car, a couple of the early MK1 cars were fitted with 427's for Le Mans in 1965, lots of aero experiments etc on these cars if you choose to replicate something a little different from the norm, Also one of the Alan Mann cars was fitted with a 427 & Webers for some time for testing transaxles etc.
Jac Mac
Old 07-31-2015, 12:41 PM
trularin's Avatar
Member of the north
I contributed to CC in 2006
I have in the past contributed to CC
Cobra Make & Engine: A Cobra
The RCR will eat anything. LOL
The car is very close to the originals...might want to give Fran a call.
and yes I have one.
Tru
Old 07-31-2015, 03:34 PM
Cobra Make & Engine: ERA 744/428/TKO 600
Is the RCR a monocoque chassis like the original? I believe ERA and Superformance are more original if that's important too you.
Old 07-31-2015, 05:29 PM
gsharapa's Avatar
Cobra Make & Engine: CAV GT40 #169, Ford 408 Stroker & ZF Transaxle
The one criteria you didn't mention is $$$$$. If that is not an issue for your customer than lots of options.
CAV GT40
Old 08-01-2015, 05:58 AM
Cobra Make & Engine: ERA FIA #2117; 331 stroker; TKO600
ERA is about as close as it gets to the original. Not sure about the Superformance .. but Superformance builds a great car. ERA stopped making the GT40 a year or so ago so you will need to track one down. All the ones I saw on Cobra Country were sold. As I recall the ERA was about the same price as the limited edition Ford GT40 run of 2000 cars done several years ago. Was around $130,000 or so without drive train.
Old 08-01-2015, 09:46 AM
SPF is much closer to original than ERA. Tub and suspension pieces are interchangeable to original, not the case with ERA. Only the steering rack, Wilwood brakes, and A/C are non original. Not knocking ERA as it's a well built car, but please don't contend it's the most original. Actually Gelscoe (U.K.) makes the most original, but $$$$.
Old 08-01-2015, 12:04 PM
twobjshelbys's Avatar
Cobra Make & Engine: Shelby CSX4005LA, Roush 427IR
SPF claims 95% parts interchangeability with the originals. I don't know if that is factual but even if it's 90% that's a pretty good "replica"...
CSX4005LA
Old 08-01-2015, 12:31 PM
They changed that to 70% when they were challenged with the 90% comment.
The steel roof is a really nice feature on the SPF. It leaks just like the original. In my opinion the fit and finish is better on the ERA but it's no longer in production.
Old 08-01-2015, 01:10 PM
gsharapa's Avatar
Here is my CAV.........408 Stroker, ZF Transaxle.
CAV GT40
  #33 (permalink)
Old 08-01-2015, 01:21 PM
gsharapa's Avatar
Couple more....
CAV GT40
  #34 (permalink)
Old 08-01-2015, 01:28 PM
Beautiful car Gary....The CAV also has the correct monocoque chassis.
  #35 (permalink)
Old 08-01-2015, 02:36 PM
fordracing65's Avatar
Cobra Make & Engine: Kirkham #684, 482FE, Mike Mccluskey build
I have driven both small block and big block roush engine in the SPF gt40, it is the real deal, the parts are interchangeable with original, the paint is perfect, the inside is awesome, the gold wheels with the red spinners per original really set it off, but the price is big time for a big time car...they both had AC which is awesome for a touring race car...
PRIDEnJOY
  #36 (permalink)
Old 08-01-2015, 07:00 PM
Cobra Make & Engine: built the molds and body composite construction
The chassis pictured above is not correct from the fiberglass forward as to an original GT-40. I will assume as pictured, that the water is routed on this car down the original side gas tank tunnels. On the original cars, the plumbing is down the center of the car, where they are putting their shift linkage now. The original is quite different. It maybe stiffer, I don't know but I do know, it is not like the original.
Bill K
  #37 (permalink)
Old 08-01-2015, 10:22 PM
Cobra Make & Engine: FFR: 302 w/aluminum heads, Edlebrock injection. Street car trim, no scoop, side pipes or rollbar.
Send a message via AIM to Maricopa
It seemed like a very lightweight racing model versus a car destined for street use.
What? A GT-40 replica that seems like a lightweight racing model? That's crazy?
"Cobra-Cobra-bo-bobra, banana-fanna-fo-fobra, fe-fi-mo-mobra...Cobra!"
  #38 (permalink)
Old 08-02-2015, 04:13 PM
Here is how ERA routes their water pipes from the forward radiator. Their monocoque chassis is a work of art...
  #39 (permalink)
Old 08-02-2015, 04:16 PM
Era gt40
