Go Back   Club Cobra > Club GT40 Areas (MKI - MKII - MKIII - MKIV) > GT40 Talk
User Name
Password
Club Cobra Home Register FAQ For Sale Calendar Today's Posts Journals
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-09-2008, 02:48 PM
Jac Mac's Avatar
Cobra Make & Engine: DIY Coupe, F/T ,MkIV.
Smile
Hersch,
The 'adjustabilty' of the RF & other spaceframe cars can be made a lot more user friendly if the inner bushes of top/bottom wishbones are replaced with spherical bushes( similar to a rod end, but press in & retained by circlips ) and the chassis pickup points reworked so that all bolts run parallel to the car centerline. This also dictates that the top/wishbone ball joint be either a rod end or threaded type ball joint ( I think they use a Ford Transit tie rod end in the UK ) for camber adjustment.
With the pickup points reworked in this fashion the castor can be changed without affecting camber or wheelbase at the same time-by shifting the lower w/bone fwd & top w/bone rearward the castor can be increased without altering the wheelbase. All this is acheived by simply altering the spacer stack on each side of the spherical joints. Doing it in this manner virtually eliminates the possibility of the tire contacting the wheel arch or sponson at either lock limits.
[NB- this only works if the inner ends of w/bones re modded as above- will not work with plain bushes or nolathane etc]
Jac Mac
Old 02-10-2008, 09:24 AM
BT SNAKE's Avatar
I have in the past contributed to CC
Cobra Make & Engine: Midstates Cobra, RFGT40
Smile
Jack,
Thanks again. I don't think you know how much that last
post helped me.
I'm currently trying to understand how the tire slip angle works with all this . Kinda hard to picture . I've heard that tires are the first consideration.
I think I will learn how to set up a suspension but the real secret is knowing what setup to use on a peticular track. It's the undersdtanding of what effects you get when you change something. Like what to change when you need the rear to be more stable in a decreasing radial turn.
I will say one thing, it's damn interesting but confusing at times.
One question Jack... I have seen front and lower wishbones with verticle spherical bearings perpendidular to the centerline of the car. What are the good - bad points of this design?
Hersh
Old 02-10-2008, 12:47 PM
Jac Mac's Avatar
Originally Posted by BT SNAKE View Post
Jack,
post helped me.
Hersh
I will answer the last Q first. The vertical bolts allow you change roll center heights and antidive @ front or squat @ rear. As Fran has pointed out you can have combos of both on one w/bone. Take the front lower as an example. If the inner front pivot has the bolt horizontal while the inner rear bolt is vertical then raising the rear of the w/bone will build in some antidive.
Dont sweat the confusion part, without a great deal of thought it very hard ( if not impossible ) to design a suspension layout where one change does not create another unwanted change at the same time- the 'trick' if there is one is to minimise these unwanted changes.
One change at a time is the safest way & keep notes. I can tell you that the car I have been involved with out here has achieved approx 4secs per lap improvement from suspension work only over the last three seasons, most of the problems were built into the car originally. With hindsight it would have been quicker to build a new chassis, but then we were not aware of what we were in for! Strengthening a weak area of the chassis that was causing a mechanical bind in the rear suspension while under power was the single big gain- a simple test of chassis torsional strength showed that up!
Jac Mac
Old 02-10-2008, 02:32 PM
BT SNAKE's Avatar
Smile
Fran,
That is a slick aproach. I'm starting to see where thinking outside the box can pay off as long as you make sure the engineering is good. Fran, I have always been impressed with your business and engineering choices. The consumer wins. and so does the industry as a whole.
Jack,
More nuggets of good advise. Thank you and I will heed those words of wisdom.
Hersh
