Old 04-17-2010, 06:12 PM
Kasi's Avatar
Cobra Make, Engine: Hi Tech CSX 3016 Sebring Clone.460 BB.4 Sp Toploader .Hilibrand Racing Magnesium Wheels.soon 427 SO aerea correct ! Block
Default Adjust-A-Jet ???
Hi Guys did somebody have expirience with this Adjust-A-Jet from Percy's High Performance Kit from Summit Racing here:
http://www.summitracing.com/parts/PH...5&autoview=sku
Is that Kit any good ???
" Better Nürburgring as Wedding Ring"
Hi-Tech CSX 3016 Sebring Clone
4.sp Toploader,42 gal Alu Fuel Cell,Secondary Fuel Pump,All Aluminum panels.
Old 04-20-2010, 04:34 PM
Kasi's Avatar
Nobody ?????
Old 04-20-2010, 08:13 PM
Kasi,
I am also interested as to anyone that has tried the Percy adjustable jet plate setup...I would mainly be interested to know if it can produce repeatable results, especially as to mixture on the left/right side of the engine.
Would guess if you had O2 sensors on both sides of the engine, this could be used to some advantage for quick fine tuning.
Some of us live at sea level, but the tracks are at higher altitudes. In Southern California I think Willow Springs is at about ~2400 feet. May be more interesting than necessary, but that describes a lot of the mechanical candy we purchase just for fun...(pretty good reason for me, entertainment!)
ERA 289 #2027
Old 04-22-2010, 07:12 AM
Cobra Make, Engine: Unique
Default Muscle car
Only time I ever saw one used was on muscle car and it seemed to work. I was curious about these but couldn't find any real world exp from anyone so went ahead and pulled the trigger for a set of quick change bowls from QFT. Just for reference the jets fit from GF to HLY but the screwdriver bit is a different size and the holley jet tool won't hold the GF jets, buy holley jets! But I am buildibng a VS for a 347 build so maybe someone will post with some info by then.
Pretty odd no one has tried them!
Old 04-22-2010, 08:42 AM
Jerry Clayton's Avatar
Adjustable jets are too inconsistant--
One of the best things about holley is that the jet numbering system is flow related, not hole size
Now other than that---float bowls that have the holes to change holley jets without removing the float bowls are a nice deal in that its easy to remove a plug and drain high octane fuel on a hot engine--- but at least you don't have to mess with the fuel lines
Old 04-22-2010, 08:59 AM
lovehamr's Avatar
Stolen Avitar
Some hits from the web;
http://www.allfordmustangs.com/forum...t-jet-kit.html
http://www.jeepforum.com/forum/f8/pe...retors-635971/
http://www.hotrodders.com/forum/holl...et-140174.html
Some good observations in these.
Steve
