04-23-2010, 01:55 PM
NJ
Cobra Make, Engine: Contemporary Cobra
really screwed my carbs up!
had a bog in my 2x4's (450's) and had tryed bigger squiters #37... not a big difference and screws in metering blocks needed tobe 2.5 turns out to run its best.
It was suggested to open the seconaries abit to help the problem...I also took off the fuel bowl to check what jets were in there #60's...now the motor won't idle,I have backed the idle adjustment screws out so there is no contact and have turned the metering block screws so there now out 1/2 turn...a little progress but not great or as good as it was before I started...next the seconary fuel bowl now dosen't have any fuel in it..I unscrewed the lower bowl screws and nothing came out. Took off the bowl and the tube that feeds that bowl was persurized with fuel and have trted to reset the float with no success......any suggestions, could use some help!
Jon
