Old 08-29-2011, 05:47 AM
desmo's Avatar
Cobra Make, Engine: Kirkham 427 S/C (KMP304) / 427 FE S/O stroked to 428ci (CSX460) / Weber 48 IDA's
Default holley electric pump
I need an advice. Since I had some electrical problems, I need to replace the fuel pump.
The carburator is a 4150 Holley 750 CFM and the engine is a 427 FE strocked to 482ci and prepared by Keith Craft. Currently the electric fuel pump is a Holley but I don't know the part number.
Do you know the part number I need to order ? Do I have to install a fuel filter ?
Thanks for your help..! (and sorry for my english)
PS : I also need to change the alternator (I have 2 battery of 28Ah each, the external regulator is brand new) but, again, I don't know the part number.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 08-29-2011, 06:14 AM
randlej's Avatar
Cobra Make, Engine: Lonestar Classics
You need a 100 micron filter before the pump and it is a good idea to use a 10 micron filter at the carb.
You might want to consider a mallory pump. I understand they are more reliable and quieter. Based on a g-rotor design.
Mallory Ignition 4110 - Mallory Comp Pump Fuel Pumps - Overview - SummitRacing.com
2009 Lonestar Classics - 351 W
Old 08-29-2011, 06:33 AM
Cobra Make, Engine: N/A
Default Fuel pump
Hi:
You have a Holley Red pump. They are internally pressure regulated at about 7 psi, so you won't need a pressure regulator. That's all you need to know, you can order the same pump, just specify Holley Red, you don't need a part number. They are noisy, but I have no experience with any others, and to fit another pump may require adding a fuel pressure regulator.
Cheers!
SPC0123
Old 08-29-2011, 06:56 AM
desmo's Avatar
Thank you, there are two references in Summit website. Which is correct and/or the best one ?
- Holley 12-801-1 - Holley Red Electric Fuel Pumps
- Holley 712-801-1 - Holley Red Electric Marine Fuel Pumps
Search Results for holley red electric fuel pump - SummitRacing.com
Any idea for the alternator ?
Many thanks.
Emmanuel
Old 08-29-2011, 07:08 AM
marco454v8's Avatar
Cobra Make, Engine: AK427 BB Chevy454
Salut Manu,
Il faut le première référence- le deuxième pour marine a 30 gph de moin.
Moi j'ai le bleu, mais il faut une régulateur.
Cdlt Mark
Old 08-29-2011, 07:06 AM
This one:
Chas.
