Old 03-03-2014, 09:31 AM
DanEC's Avatar
Default Holley secondary vacuum canisters on dual quads
Still planning to spring for a set of correct, restoration, custom tuned carbs for my motor. Mickmate has suggested someone that he has had a lot of good experience with. The original carbs had a vacuum hose joining the secondary canisters together to equalize opening of the secondaries. Most Holleys don't have anything like this as I assume it's only usefulness is in dual quad and tri-power set ups. Is the vacuum port secondary cap a Holley option? Or is it a rare, original, scace as hen's teeth part with a hefty price tag?
Old 03-03-2014, 10:02 AM
You need this kit. It comes with a pair of the equalizing caps.
http://www.summitracing.com/parts/hl...FdI7OgodAiAAgw
Your nearby auto parts store will have the proper 3/16" i.d. rubber vacuum hose to connect the pair.
Old 03-03-2014, 10:28 AM
We connect them on all of ours.
Old 03-03-2014, 10:41 AM
DanEC's Avatar
Well, that was easier than I expected. About choked on the price until I saw that was for the pair.
Old 03-03-2014, 01:27 PM
So did I! Seems like $40ish would be a fair price, but these days a dollar doesn't stretch very far.
Old 03-03-2014, 01:37 PM
LMH's Avatar
LMH LMH is offline
Carls Ford parts has them also. That's where I got mine.
Carl's Ford Parts
Alba gu brąth
Old 03-03-2014, 01:54 PM
Carl's Ford Parts
A little less expensive from Carl's!
Old 09-21-2014, 10:18 PM
Cobra Make, Engine: ERA 427 S/C, Ford 427 Side-oiler 2x4 bbl
I made my own for my son's '67 GTO with 2 inline 4's (Holley).
I started by drilling a hole in the center of a couple of 'stock' caps.
I tapped the holes for a 90 degree brass fitting (1/8" (?) NPT).
The fittings were NPT on one end and compression on the other end.
Then I used a short length of copper tubing with compression fittings to connect the two together.
If you're worried about looks you can polish the brass and copper parts and it looks kind of 'retro' or "Rocket Man-ish".
Phill
