Go Back   Club Cobra > Engine Building, Tuning, and Induction > Holley Tuning
Old 07-25-2015, 06:20 AM
Cobra Make, Engine: Backdraft 1048
Default Wideband 02 sensor
I'm finally looking to put a wide band 02 sensor and gauge in my backdraft. I'm thinking about a gauge that mounts to or in the dash. Looking for suggestions and exact mounting location of the bung.
Thanks
Gary
Backdraft 1048
Old 07-25-2015, 06:36 AM
DonC's Avatar
Cobra Make, Engine: ERA #684, 428 FE, TKO600
Mounting location for the bung will depend on how your exhaust system is configured.
As a rule of thumb you want it as close as possible to the exhaust ports at a point where the exhaust for all four ports is passing.
If you're running individual header pipes to a collector put it in the system at the collector or somewhere down stream. In some systems this will put it a long way from the exhaust ports. I believe the general consensus is within about 18" or closer to the exhaust ports for best results.
DonC
Old 07-25-2015, 12:59 PM
Cobra Make, Engine: Shell Valley, 351W
I made a little gauge pod for my wideband meter and a vacuum gauge and mounted it below the dash. I installed bungs in each collector. It works fine.
Old 07-26-2015, 10:30 AM
zrayr's Avatar
Cobra Make, Engine: Fords
I recommend the AEM gauges . I have my sensor(s) about 2 inches downstream of the headers. I tried their digital gauge for a few years, but switched to the analog type. Looks better in a vintage car to me.
Z.
'65 K code Mustang
'66 Galaxie 500
