Go Back   Club Cobra > Manufacturers, Engine Builders, tools, and parts. > Hurricane Motorsports
November 2025
9 10 11 12 13 14 15
16 17 18 19 20 21 22
23 24 25 26 27 28 29
Old 02-26-2006, 10:17 AM
Default how many are running big blocks?
Just curious how man here are running big blocks in their cars. Any over heating issues?
Dan
Old 02-26-2006, 10:53 AM
sparks's Avatar
Cobra Make, Engine: #1459 w/460(sold)New(used),spf w/427s.o.(sold)
i had a bored 460 and i never even got close to overheating. never even noticed the cab to be warm , except for the sun beating on my head......
Old 02-26-2006, 11:40 AM
FUNFER2's Avatar
I have a original Shelby 428 FE that his team built in glory days. 560 hp. Never over heats. It 90 (+) deg. traffic, it may get to 210. This year with a better cooling fan & shroud, I'm sure this will bring it down further.
Kev
Regards,
Kevin
Old 02-26-2006, 11:53 AM
CaliCobra's Avatar
Cobra Make, Engine: Nuttin'
I'm runing a 429 with no heating problems at all. The engine compartment does have a fan shroud that doesn't "waste" any of the air flow coming in from the nose.
Old 02-26-2006, 12:10 PM
LMH's Avatar
LMH LMH is offline
Dan
In the Hurricanes, I know of two with one more being planned. I have not heard of any cooling troubles.
Old 04-11-2006, 10:26 AM
khansmith's Avatar
Cobra Make, Engine: Hurricane Motorsports, Southern Automotive 428 FE
I will be running a 428
Hurricane Motorsports: HM1046
Follow the build on my blog: http://khansmith.blogspot.com/
1974 Pantera resurrection blog:http://1974pantera.blogspot.com/
Old 04-11-2006, 01:52 PM
Cobra Make, Engine: ERA # 695 w/Shelby alloy block 427#CSX506 w/Richmond 5 speed
Mine is a 427 stroked to 468 with a Shelby aluminum block and Edelbrock aluminum heads. No over heating problems.
Fast is fun!
Old 04-11-2006, 03:01 PM
427SnakeSC's Avatar
Cobra Make, Engine: Shelby CSX 4995, Keith Craft built 427 SO
Send a message via MSN to 427SnakeSC Send a message via Yahoo to 427SnakeSC
I have a small block in my Classic Roadster now, but will be running a KC 427 in the new CSX on order.
"The 427 Cobra is easily the highest performance car ever sold for street use. A decent 427 - not the worst, not the best, will go from zero to 100 mph and back down again to zero in less than 14 seconds. All thing considered, you can put together a pretty good argument that the 427 Cobra is the ultimate performance car, judged on any basis you want to name." Taken from; Corvette, The Sensuous American
Old 04-11-2006, 05:27 PM
Cobra Make, Engine: original a/c. shell valley 427. daytona coupe
Just took one of our new shell valley 427's out for it's maiden voyage Although this car has only a built t-bird 390, It is very fun ,will press you back deep into your'e seat and put a big smile on your'e face. gotta love those FE's......................
Old 07-01-2007, 08:03 PM
I have a chevy big block and I do have over heating if I stop for any length of time.I do not have a hood scoop and I am going to install one with a cool air box under the carb and will see if that helps.
Old 07-03-2007, 10:58 AM
Cobra Make, Engine: currently shopping
Default Chevy ??
must be running a fever...organ rejection !!
Old 07-03-2007, 01:16 PM
Don McCain's Avatar
Cobra Make, Engine: Shelby CSX4870, Shelby 496
Default Overheating
I just finished a 496" for my S/A Cobra and haven't had any problems and its so hot in L.A. that fire hydrants are chasing dogs. Engine is all aluminum with 10.5 to 1
Old 07-03-2007, 02:13 PM
jdog's Avatar
Cobra Make, Engine: Shelby CSX4795 (Sold)
Arrow Original sideoiler
Original 427fe sideoiler:
jdog
P.S. I wish you could hear the beautiful sound this thing makes!
"If you can't run with the BIG DOGS, stay under the porch!"
Old 07-03-2007, 10:05 PM
Chaplin's Avatar
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Mpotito-
You have a pm.
Replica is not a dirty word.
Old 07-04-2007, 06:37 AM
Dwight's Avatar
Mike Lane run a KC 461 in his Hurricane. No problems 4000 miles.
Dwight
Old 07-30-2007, 07:09 AM
Bill Bess's Avatar
Cobra Make, Engine: Arps/Burroughs/Hurricane/428FE
Smile Desert Cobra...sort ofa Hot Head!
Dan, I have a SA 428 FE in my Hurricane and it is great fun. It tends to run a little hot in traffic, but cool on the road when there is plenty of air flow.
I just installed a full fan shrold on the puller fan and will be testing it soon to see if it helps. In addition, I have not had all the alum. ducting in place prior to completing the bodywork so that alone may help.
Another thing, here in Lake Havasu City, AZ. its 90 degrees at 6 AM and 120 on some days during the summer, so the poor snake doesn't have chance to get too cool.
Anyway, see you later, Bill
Old 07-30-2007, 07:33 AM
Cobra Make, Engine: FFR 3881 427 FE w/2x4bbls and 4 spd toploader
No over heating issues with my poked and stroked 427 FE. It is very thirsty though.
RB
Old 07-30-2007, 07:35 AM
Naumoff's Avatar
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
482FE w/Fan shroud and big amp alternator to run it. No problem.
It is hot in So. MD in the summer months.
Airflow at stop lights seems to be a big factor.
Old 08-01-2007, 07:20 PM
limebluie's Avatar
Default Custom Hood to fix overheating problem
In the past I had overheating problems. Also, the car was limited on the amount of space under the hood to fit a PROPERLY sized air cleaner to feed a BB at 6500 RPM. I was forced to make a completely new hood and master mold. Take a look at my pictures.
The car will not overheat, even in stop and go traffic!
Old 08-02-2007, 07:03 PM
PaulProe's Avatar
Cobra Make, Engine: Hurricane - FE
Default Counterflow radiator
I am using a dual path radiator in mine to increase cooling efficiency. Both ports are on the drivers side.
Paul
www.65shlb.com
www.prdcrrct.com
